Volks AutosAH Fabrications
Results 1 to 12 of 12
    May 2012
    32
    Replacement lower front grill on 53 plate
    Hi
    I've mysteriously lost a chunk out of one of the horizontal bars in the lower front grille on my 53 plate TDI Sport. Does anyone know if I can get a replacement lower grille and if so whether it's easy to fit or can this only be replaced with a whole new bumper?
    I can see replacement upper front grilles for sale for my model but not the bottom one. Not the biggest problem in the world but I notice it every time I'm walking up to the car now and it annoying me!
    Fossie
    Rhubarb Triangle
    3,961
    I think that is classed as the spoiler and goes right across the front. Do the air intake grilles fit into it ?
    If so it's part number 8L0 807 110 F ( 3FZ black ).
    About £100 from Audi
    May 2012
    32
    It's broken where the white arrow points:
    I was hoping I could just replace that central black bit.
    Fossie
    Rhubarb Triangle
    3,961
    OK - classed as Air Guide Grille lower centre
    Part No. 8L9 807 683 (3FZ black )
    About £45
    May 2012
    32
    Cheers mate, is it difficult to fit?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    You'll need to take the top grille out so you can reach down behind and pop out the lower grille (has tabs all round the outside).
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by StewMang View Post
    This is the 8P section of the forum. As your car is an 8L perhaps you might get more help in that section.
    Good luck.
    May 2012
    32
    Cheers that doesn't sound too difficult, presumably the new one would just click into place after?
    May 2012
    32
    Mine is an 8P.
    Fossie
    Rhubarb Triangle
    3,961
    Mine is an 8P.
    Whoops - sorry my bad !
    Part number for air guide grille lower centre is :- 8P3 807 647
    About £40
    Sorry for the error !!
    May 2012
    32
    About £40
    No worries mate, I did wonder when you put that and I noticed the 8L at the start of that part code!
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Yes it just pushes back in.
  1. Lower front grill
    By jd26 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st October 2011, 22:52
  2. s-line lower front, grilles won't fit???
    By jbcalvin in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd May 2011, 13:06
  3. Removing lower front grill?
    By nickelvery in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2007, 11:40
  4. S3 Lower front grille clips
    By madvw in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2007, 17:38
  5. Lower Front Grille
    By Lowride in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th March 2005, 22:34
