Badger5Chris Nott
    Nov 2012
    57
    Turbo whistle on idle - SHould i be worried?
    So i have had the A3 now for just over 4 weeks and painlessly covered 2.5k miles HOWEVER i have noticed a fair amount of turbo whine not Siren just a bit more whistle/whine than the other 5-6 VW's 2.0 TDi i've owned. Appreciated the car has covered nearly 90k miles so there is going to be some whistle but after 4-5 minutes of the car idling there is a slight whine/whistle that sounds like the radiator fan (in fact that is what i thought it was) and goes away if you blip the loud peddle.
    As i said, i have owned 5-6 MK5 TDI Golf variants the last three have been the same engine (BKD) and this is the only one which as whined.
    Feb 2011
    Plymouth
    1,110
    Mine is like this too, sounds like a huge boost leak on idle also sounds like a supercharger at higher revs when accelerating. When turning it off and back on again it sometimes goes away. I'm just waiting for the turbo to give in.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    I've had that whine for at least 6-8 months now, maybe more. Turbo was replaced around 25k miles ago. No overboosting, loss of power, blue smoke or limp mode so just driving the car as normal.
    VCDS USER
  1. Turbo whistle
    By mjepson in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2 Weeks Ago, 08:32
  2. turbo whistle
    By jamzee500 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2007, 18:24
  3. Should I be worried?
    By AlexStanley in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2007, 15:29
  4. Replies: 4
    Last Post: 2nd June 2006, 20:09
  5. Turbo whistling, Advice requested?
    By A4Steve in forum Diesel forum
    Last Post: 5th March 2005, 17:59
