    Nov 2012
    47
    Exclamation IMF part number?
    Hi can anyone tell me if this is the correct part for the Intake manifold flap motor?
    Pierburg - Euro Car Parts UK’s No.1 Retailer
    It comes up as throttle body? Anyway, if anyone has orderd from eurocarparts, can they confirm if this comes with the rubber seals etc for the turbo boost pipe etc. also, what else do I need to replace with the IMF.. I have read about seals and some gaskets but which ones? Any help will be appreciated.. Also, how long does this IMF last before it goes faulty again? Also, I'm averaging around 31-32mpg for local driving. Is this number low because my car has the IMF fault or is this normal? I've checked and pumped up the tyre pressures, only thing to do Is replace the rubber seals for the intercooler pipe and will get this done by audi tomorrow. Anything else that can hinder mpg performance? All replies will be deeply appreciated. And I'd like to thank all the guys who have replied to my previous posts, you guys are the best :-)
    Fossie
    Rhubarb Triangle
    3,961
    It's difficult to help without the year of car and engine type.
    However, if you fed your cars' information into the selector page at ECP then I'm sure it will be right. Don't know about any other bits though.
    Nov 2012
    47
    Audi a3 sportback 2007 plate, engine code BKD. Does the throttle body have the get valve built in and will I have to replace that too or just give it a good clean?
  1. Oil used in servicing part number
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2003, 15:39
  2. TT linkage for A3 part number
    By phillj in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2003, 16:58
  3. TT pedal set part numbers
    By ooooaudi in forum TT/TT-S/TT-RS Forum
    Last Post: 9th April 2003, 20:20
  4. tt pedal set part numbers
    By ooooaudi in forum General Technical / How To
    Last Post: 9th April 2003, 20:16
  5. ECU part number
    By stumunro in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2003, 12:49
