Volks AutosMonster Motorsport
Results 1 to 13 of 13
    Dec 2012
    Northampton
    10
    A3 Quattro hesitation on hard acceleration??? Audi can't find fault!!
    If anyone can help I'd really appreciate it. I have a audi a3 Quattro 170 sport back when i brought it i had a dpf fault with turned out previous owner had had it removed but not deleted so i have since had it deleted from ecu and at same time i had it remapped to 210bhp! But since this it hesitates under hard acceleration happens in 3rd 4th 5th and 6th between 2 and 4 thousand revs. If you accelerate gently its ok. I have put it into audi they had it for 2 days and can't find the fault. They have tried injectors, changed the fuel filter, and checked egr valve, and exhaust pressure sensor. Thanks in advance for any help.
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,794
    Who mapped it....?
    Sounds like wrong fuel, air etc values...?
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Dec 2012
    Northampton
    10
    It was a bloke in Northampton! He reckons his put the same map on a passat which is fine no problems.
    Before the remap it had a tiny bit of hesitation in 3rd but nowhere near as bad as it is now!
    Aug 2011
    Sunderland
    31
    Quote Originally Posted by mjr901 View Post
    Who mapped it....?
    I agree i'd take it back and get him to do it again, it may need a little tinkering to get it right but it depends on if they know what they are doing or just loading a std map.
    A3 2.0 TDI S-Line Quattro (200 bhp+) BFT tuned DPF removed.
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Quote Originally Posted by A3 Tom View Post
    If it was doing it before the map, then it's not the map at fault. All the map will do as you have found out is highlight the issue further due to the higher demands requested. As for the fault, it sounds like a sensor possibly throttle position as this would tell the ecu what is required amongst other things...
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    496
    Have you had the injectors replaced?
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,484
    cam follower checked?
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / BCS Powervalve TBE system / LOBA HPFP / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    Dec 2012
    Northampton
    10
    Thanks for all the replies I think we have found the problem seems like it was already mapped before but a bad one. Then the new map on top off that made it worst. The tuner has now got me the original file and tuned that so fingers crossed! Thanks for you help.
    Audi Heaven
    Somerset
    1,861
    Dont believe that... I thought if you mapped it you replaced the hole file, not part of it.
    Scott
    Dec 2012
    Northampton
    10
    Just come back from the blokes house. His took old file off and put new one on seems to have worked seems smooth again. So fingers crossed its fixed. Now time for a few mods
    Mar 2007
    Cambs
    471
    Its not blue reg starting MA by any chance is it?!
    Dec 2012
    Northampton
    10
    Quote Originally Posted by Cossie_boy View Post
    No it's lava grey reg starting ma??? Im interested why you ask?
    Mar 2007
    Cambs
    471
    Ah ok then, I thought you may have bought my old car as it had pretty much exactly what you are describing
  1. my11 S3 hesitation under hard acceleration...
    By mojo555 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th November 2010, 15:36
  2. Third gear not going in smooth under hard acceleration
    By siruz in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2010, 12:11
  3. Squealing noise under hard acceleration
    By dcallaghan in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th October 2004, 13:12
  4. Where can I find a 1.8T Quattro?!
    By jonblakeburn in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th November 2003, 21:43
