Chris NottMonster Motorsport
Thread: S3 Knocks
    Fandango80's Avatar
    Oct 2004
    Poole, Dorset, UK
    71
    S3 Knocks
    Hi all!
    Had my s3 for a couple of years and have a couple of issues.
    Knock 1
    When I turn the wheel in no particular direction, at low speed you sometimes get a light knock just the once which you feel slightly through the steering wheel. Nticable when parking. Audi replaced the steering rack under warranty, greased top of the spring seats and can't figure it out. Any ideas?
    Knock 2.
    Went through some reasoably deep flood water the other day and a couple of days later got a knock when I dropped down a gear and came off the clutch with no throttle. If I pulled away abruptly it would knock again. It would only knock once in each direction at a time, ie. drop down a gear and release the clutch - knock. Dip the clutch and do it again and no knock. Accelerate and then drop down and release the clutch and knock again. Thought it could be an engine mount but my friend at Audi suspects a dual mass fly wheel. No rumbling or vibrations though. So here's the weird part... It stopped. Hasn't come back for 4 drives now. Any ideas?
    Cheers guys.
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,814
    Get the rack checked again and I would maybe check your gear box mount.
  1. Knocking from the front during gentle braking ???
    By noodle in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th January 2008, 22:29
  2. Knocking sound
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd May 2004, 19:14
  3. (Rear?) Suspension Knock on S3
    By gdwood in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2003, 19:05
  4. Knocking Noise
    By L1ARR in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2003, 17:19
  5. What can knock a knock sensor?
    By MisterD in forum General Technical / How To
    Last Post: 20th May 2003, 13:53
