Monster MotorsportBadger5
    BigWillyStyle's Avatar
    Aug 2012
    566
    Why is it happening?
    For some reason when i switch on the heated rear window it interferes with my radio!
    It has only just started which i dont understand. Does anyone know how to fix this?
    Thanks in advance....
    Nov 2011
    13
    Quote Originally Posted by BigWillyStyle View Post
    Hello mate, ive got the same with mine but i use my iphone more than the radio so it doesnt bother me enough to fix it!
    The cause is a seperate amp / splitter unit located in the tailgate i believe. Your car uses the heater element in the rear windscreen as the antenna, there is a splitter to stop intereference when its used with the radio. Its this splitter box failing that causes the problem and is a common problem. The box is not expensive but i remember someone saying was a pig to get to!
    I hope that helps!
    Aug 2012
    566
    Ok thanks i'll have a look at it!
    Do you know what the name of the actual part is so i can look for one? Thanks
    Nov 2011
    13
    I think its just an Antenna Amp although i think NHN might be your man, he knows his stuff when it comes to electronics so he would be your man to ask!
    Drop him a PM im sure he'd be able to help, he'd probably be able to source it for you, i know he does a lot of stuff for other forum members!
    Aug 2012
    566
    Ok thanks again, i will send him a PM!
  1. Why is this happening
    By Knightster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2012, 17:26
  2. Why did Audi leave WRC?
    By AL_B in forum Motorsport
    Last Post: 26th June 2006, 17:34
  3. Why dont Audi
    By richyboy in forum Diesel forum
    Last Post: 27th February 2005, 23:39
