AH FabricationsEM Tuning
Results 1 to 10 of 10
    Mar 2011
    Tyre noise and pressures
    When I bought my Audi A3 8P second hand it had a full set of Federal tyres. The grip wasn't very good in them but above all the road noise was loud!
    I decided to upgrade and bought some Michelin Pilot Sport 3 tyres 225/40 R18, the road noise dropped right off to the point that I could hear the diesel engine where previously it was just a continual load road noise. They new tyres were nice and quiet for the first couple of weeks but have now started making a lot of road noise again. I had the alignment done and still the same, it mainly appears when I go above 45.
    I wondered if it was due to tyre pressure? What do others with the 225/40 R18 have the pressure at? I can't remember exactly what mine are but I set it at the "2 people & 1 piece of luggage" pressure that is listed on the inside of the petrol flap. I don't have any other issues like vibration just the noise.
    Thanks!
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    Could be Wheel bearings?
    2005 Audi A3 2.0 TDI DSG S-line (8p1)
    Mods: 18" Gloss Black RS4's - 8p2 S-line Front Bumper - Black Grill - A5 LED Number Plate lights - LED Sidelights - Euro Style Plates - EGR Delete - RTech Custom Remap - Hot Start Issue Fix
    Pipeline: Lowering, Wheel Refurb, Coming Home Lights
    2007 VW Golf 2.0 GT TDI 140 (Wife's)
    Mods: 18" Charlestons
    Yiddogaz's Avatar
    Nov 2012
    Tyne and Wear
    31
    Try tyre pressures set them for whatever it says on filler cap, then if still bad check bearings like above said
    Boydie's Avatar
    Boycie
    Dec 2006
    Greenisland, Co.Antrim
    4,767
    Also check your tyres - I know they are new but tyres can twist. I had this problem in the rear tyres on my old A3. I swore the bearings were gone, had them priced up and was ready to pay when someone suggested to check the tyres.
    Took the rear tyres off and the inner half was like the Himalayas!
    Mar 2011
    May sound stupid but is there a way of checking the wheel bearings?
    Boydie's Avatar
    Boycie
    Dec 2006
    4,767
    Yeah, take off your wheel, turn the hub. If you feel a flat spot or hear a roughness in the rotation then the bearings are gone. If they turn freely with no friction or noise, they are fine.
    Mar 2011
    Had it in to be looked at today by Kwik-fit as they fitted the front tyres and it is the front wheel bearings. They are quoting £400 all in for replacing and alignment, does that sound about right? I'm now worried of driving it elsewhere to save £100 or so in case the bearings totally fail as its been noisy for a few weeks now.
    chris.vincent3's Avatar
    Apr 2012
    UK, Portsmouth
    568
    My advice would be to go anywhere else other than kwik-fit, even if it is more expensive elsewhere. They can't even spell quick right! sheesh.
    Yiddogaz's Avatar
    Nov 2012
    Tyne and Wear
    31
    Mate like he said kwik fit for the majority are overpriced and ****, go on the goodgaragescheme.co.uk and find one in the area. Tell them what kwik fit said to you and get a quote, may as well do this for a couple on the site. Then ask them to make sure it is the bearings as knowing kwik fit it might be they've messed up on the tyres. I don't see why they need to do alignment either I never have on my other cars haven't done it for this one all you do is pop track rod end out you don't have to unscrew it.
    Let me know how you get on!
    J8TT X's Avatar
    Jan 2011
    Leicester
    327
    £400? for both?
    I got my front drivers side wheel bearing changed at kwik-fit in Cov for £170.
    and that was about a month ago.
    I did look around and the next cheapest quote was £200 from a local garage.
    The part costs £116 as its the whole hub that needs replacing.
    and its about 1.5 hr labour per wheel.
  1. 3.2 tyre and pressures
    By wickyianr1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2009, 21:36
  2. Tyre noise
    By mfspen in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd June 2006, 18:04
  3. Tyre Noise
    By S3DBW in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 18th May 2005, 16:18
  4. Tyre Noise
    By bigmoose in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2005, 11:50
  5. Turbo noise and type - looking for some help
    By Holywood in forum Diesel forum
    Last Post: 28th August 2003, 16:47
