AH FabricationsBadger5
    Apr 2011
    63
    Can sombdy make me a favour?test his battery to compare?
    I changed my battery (bosch 72ah or 74 ah i think it was) yesterday through garranty ,it lasted 4 months...
    however i started my engine today 2.0 tdi and i measure 14.3 - 14.4 which is great!but ... when i switched on the heat plus the lights (xenon) i saw 13.6. Is this ok?Can somebody check his car if has similar numbers? thx in advance
    Fossie
    Rhubarb Triangle
    3,969
    That is ok and perfectly normal. Bear in mind that these are 12 volt batteries so provided you don't get a volt drop below that when the engine is running you will be fine.
    Boon's Avatar
    Sep 2012
    South East Kent
    427
    I'd get the alternator checked out just to be on the safe side, doesn't matter how good or big the battery is if it isn't getting a good charge.
    You should be getting close to 14.4-14.8v no load & ideally no less than 14.0v
    12.6v fully charged, engine off - anything below 12.0v you are looking at a dying battery
  1. can i make my car quattro?
    By ALPINE in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th September 2008, 19:01
  2. How can I make the 1.8 non turbo engine quicker???
    By Nevdog02 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2007, 20:50
  3. Can you make clutch-pedal-action feel lighter?
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2006, 21:31
  4. How late into my order can I make changes?
    By in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st July 2005, 18:08
  5. can u make the s3 4wd system permanent?
    By ianhg in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th February 2005, 11:07
