Badger5Monster Motorsport
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Question Clutch ... decisions decisions
    My car currently has a uprated sachs organic clutch with the Oem fly wheel.
    Its running arround 285bhp.
    i have a feeling my clutch may be coming to its lifes end .
    what clutches you guys recomend and what suppliers ??
    fitting is not a problem as i can do this myself however looking for advise on what clutch you guys recomend. i like the feel to mine now so may end up getting the same.
    whats you verdict guys ???
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    Quote Originally Posted by Johnson3 View Post
    My car currently has a uprated sachs organic clutch with the Oem fly wheel. Its running arround 285bhp. i have a feeling my clutch may be coming to its lifes end . what clutches you guys recomend and what suppliers ?? fitting is not a problem as i can do this myself however looking for advise on what clutch you guys recomend. i like the feel to mine now so may end up getting the same. whats you verdict guys ??? Thanks
    The uprated Sachs worked on mine up to 440lbs,so if treated right,they are pretty tough,although early failures are also reported,but I would be looking at either a replacement Sachs or the Loba/Sachs on your car,which isn't running silly levels of torque.
    If you do want something stronger,then the Loba/Sachs is a good deal tougher,but like many,is an SMF setup,so you will get a lot more grumbling at idle,and if you really plan on going the whole hog,this is what I use..... Spec Stage 3+ clutch
    pinterovski's Avatar
    Oct 2010
    661
    Add pinterovski on Facebook
    Loba/Sachs here!
    Really nice piece of kit!
    Black roof,Tinted windows,Solar Orange Calipers,KW V3 Coilovers,
    HEKO Wind Deflectors,CAI ITG Maxogen,Non Res Supersprint Exhaust CB with custom Fi76mm DP,
    RevD with GFB DV+,Autotech HPFP,Custom SKN map Stage2,Forge ShortShifter,THS mounts,
    Twintercooler,Clutch is now on LOBA/SACHS!!!
    18 OZ Ultraleggera!
    365HP and 500NM of torque!
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    How do you find it in everyday use ?
    Thanks for ur view
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,394
    How do you find it in everyday use ? Thanks for ur view
    I found the uprated Sachs was a little heavier than the stock clutch,but otherwise easy to use and reliable....the Spec is a bit heavier again,and being an SMF setup,there is a lot of grumbling at idle,but for a clutch that will handle nearly 600lbs,it's light and easy to use.
  1. Decisions decisions...... S3 or company car???
    By C_Audiboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2006, 12:07
  2. Alu mirrors... decisions decision
    By jediknight in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st December 2004, 17:33
  3. Decisions-Decisions...
    By A4Steve in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2004, 10:00
  4. Decisions Decisions !!!!
    By chester2000 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 23rd June 2004, 14:07
  5. Decisions, decisions.
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2003, 17:17
