EM TuningAH Fabrications
    Mar 2011
    15
    Diagnosis? - oil leak pics - 2005 3.2
    My car (2005 3.2 manual) went to audi for its MOT and they highlighted a 'potential prop leak' it passed and they included it as an advisory and wanted £250 for further investigation. Ermmmm......No thanks.
    My dad's got a garage and ramp so had a look. Took the undercarriage cover off and saw this........
    This area just above the sub frame looked about the worst, I did my best to take a couple photo's..........
    It feels like power steering oil but as it has no reservoir could not check level. Checked gearbox oil level and thats fine. It doesn't look like its coming from the prop but has maybe covered it and since been sprayed everywhere??
    Looking from above down the back of the engine it is also wet, from around where the lamda sensors are on the downpipes and below, all over the sub frame. Is the power steering system a sealed system built into the steering rack or is there someway of checking the fluid?
    It did have an issue with cutting out when the revs dropped below 600-700rpm? The yellow ESP light came on and stayed on for a day. Then the next day it was fine and it has been since. It threw up a code for an MAF fault, but I cleared it and had no trouble...........touch wood!
    Any ideas before I'm let loose with a socket set?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Have you recently topped the engine oil up?
    Lewis583's Avatar
    Mar 2010
    872
    On the 8P A3's the steering is assisted via an electric motor. So no fluid to leak.
    First and foremost, get some degreaser down the back of the engine and clean as much off as possible. By chance can you see the highest point where the oil is? (half way up the engine, from the top, or is the engine bone dry)
    2008 E92 BMW 335i M-sport
    1990 Golf GTi w/ a 20v heart BUILD THREAD
    Full VCDS
    2006 A3 2.0T quattro S-line R.I.P. You will be missed.
    ** Breaking - 8L 1997 Audi A3 1.8T. **
  1. Turbo Oil leak, Easy Fix? (Pics)
    By RyanS3TT in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2011, 15:26
  2. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
  3. Oil Leak 4 days after i bought car
    By imported_andrew74 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2004, 12:28
  4. Oil leak found after having car at dealers
    By ianburtney in forum General Technical / How To
    Last Post: 14th June 2004, 08:19
  5. Oil Leak found after having car at dealer
    By ianburtney in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th June 2004, 08:16
