Sky InsuranceVolks Autos
    Tay
    May 2012
    Warrington
    366
    Hesitation at 5k / Spark Plugs?
    I've got a slight hesitation around 5k intermittently on my Stage 1 S3, got a slight feeling it could be either spark plugs or coil packs. Anyone had a similar problem?
    If it is the spark plugs, what do you use with your mapped cars?
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Could be plugs/coils or fuel pump/cam follower issues.
    For a Stage 1 S3 you're better off running a plug that is one stage colder than stock. Most favour the NGK BK7EIX. These solved my Stage 1 A3's hesitation issues and I've run them in my S3 since day 1.
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,362
    Quote Originally Posted by Tay View Post
    I've got a slight hesitation around 5k intermittently on my Stage 1 S3, got a slight feeling it could be either spark plugs or coil packs. Anyone had a similar problem?If it is the spark plugs, what do you use with your mapped cars?
    Hesitation like this is usually plugs.....I use the OEM plugs on mine,changed every 7-10 000 miles,and they're fine on the road or track.
    Tay
    May 2012
    Warrington
    366
    Quote Originally Posted by S3Alex View Post
    No issues with the standard plugs? Gonna speak to Awesome see what they advise, but I'd prefer OEM plugs as I've heard of a few people have problems with aftermarket plugs.
  1. spark plugs
    By Danielson in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th September 2004, 17:02
  2. Spark Plugs
    By Bradley in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 19:23
  3. Misfire and Spark Plugs under warranty
    By DuncS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2004, 10:39
  4. spark plugs....???????.....
    By smudgy57 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2004, 17:33
  5. spark plugs
    By sahk in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th April 2004, 01:23
