Is my RNS-E a retro fit?
Ben S3 8P3
Bury//Manchester//Leeds
Is there a simple way to tell if the RNS-E unit was a factory or retro fit? Because the AUX facility doesn't work and I don't have amazing radio reception.
If it is retro-fit how do I get the AUX to work?
Thanks, Sorry for being a complete Audi noob
Ben
If you have a RNSE and there is no sharkfin aerial on the roof then it is definitively a retrofit, as most people dont bother to put sharkfin as it involves drilling the roof. Another way is to pull out the unit and see if there is any adaptors converting the old connectors to rnse connector.
Have a look in your service manual or in the spare wheel location in the boot where you will find a sticker with lots of PR options codes codes on (3 characters).
Then tap them all in to here- VW Group Option Codes Decoder
Not sure which one RNS-e is though.
I do not have the sharkfin on my roof. So thanks for very quickly solving that one for me.
Is there a way to improve reception / sort my AUX issue. Everything else works fine eg, satnav, cd player etc
The radio reception seems to suggest it might be - I believe the RNS-E uses a different antenna system to the other head units. Although the old one will work, sometimes it doesn't work great for people (bad reception etc). I've upgraded from a Symphony II+ to an RNS-E without bothering to upgrade the antenna (to save some money) and it's been fine for me. It's hit and miss with some people.
One thing you could do is check your vehicle identification sticker (should be one in your boot and one in the front of your service book) and run the codes through this website...
That should tell you what your car came out of the factory with.
Sounds like you need a new radio antenna which is located in the boot lid, it's not cheap. What year is your A3?
Its a 59 plate.
Oh well, im not too bothered about the radio, its not bad when the volume is low, but then a bit distorted when you turn it up.
I just wanted to get to the bottom it. Is the AUX also expensive to sort?
Thanks very much for everyone help and quick replies !
Don't know too much about the AUX but this may help - rnseauxin - Audi Retrofit
And also, as yours is a 59 plate it has the antenna in that's not as good as the older models unfortunately. Mines an 09 plate and chose to have mine changed when I had my RNS-E put in by Nigel.
Auxiliary is only 3 wires and as its a retrofit they will still be in the quad lock connectors, so they need to be removed and you will need to buy a multimedia adapter from audi for like £3 and move them into there. You need to get a photo of a concert/symphony sticker on the top showing the connections and then look on your RNSE and see the positions were they need to go in on the new 32 pin multimedia plug. Connections will read LEFT, RIGHT and GROUND.
I have a shark fin in my S3 56Plate... But no RNSE... Does that mean it should have one?
This will be for your Bluetooth/phone prep as its used for that as well as sat nav
I heard the four vertical lines on the rear window (like the heater elements but up and down) are the radio antenna? Could be wrong though.
P
903
68
3K
