Fan Heated Washer Jets
yacobwood
NULL
Hi,Ive been looking into this and ive seen many different part numbers and some people saying they need to be glued. Has anybody got a part number for a fan type washer jet thats heated and will fit my 07 A3?Cost of the item would be great too. Thanks All...
It says 5MO 955 986 9B9 are heated but it doesnt mention Fan....
well somebody loves the exclamation mark key.... steady on big man
hi guys, sorry for the resurrection!
Rang TPS with the 5MO 955 986 9B9 part number. Tried with with and without the 9B9 and with/without the C-suffix that's meant to be the latest part. They're saying it's not a Passat part number too.
So, just wondering if there is an update to the info? I'm looking to replace existing heated jets on an 8P2 S3 to the fan ones.
If "passat" ones are still applicable is there an updated part number, or can I just say "heated washer jets of an XX plate Passat please"
Cheers!
5MO 955 986 9B9 is the heated jet part number
you need these shims too, they take the slack up and stop you having the need to use silicone/glue 8E0955431
The shims are £1 each something from vw, i got some last week
Saw the Epsom Audi dealer - they have the part available but as stated before there are two versions ending with C and without - which is the one to get?
damn, can't find any B6 passat heated jets on UK ebay!. I'll try the VW dealer with that part number then, TPS didn't recognise it!
So basically it's the B6 Passat ones then
cheers guys
Any ebay should do. Just open it and see what it says. Ebay is good finding locations and changing del options etc.
639
805
