AH FabricationsEM Tuning
Results 1 to 19 of 19
    Sep 2012
    24
    Replace non bose sub - advice
    Can anyone recommend a new sub for the non bose amp?
    I've trawled various forums for answers but there just seems to be posts about new bigger subs and new amps. I'm happy (enough) with the OEM speakers and Alpine head unit, but the sub in the boot is burst so I need to replace it.
    I've taken the boot panels easily enough to replace it, but I don't want to start pulling more panels off and rewiring. I just want a decent replacement sub that'll do at least the same job as the standard one. I know it won't blow anyone away, but with a bit of dynamat it does the job I need it to do.
    Any help/advice would be appreciated. Like I say, the simpler the job the better.
    I'm not lazy, I'm just content!
    Cheers in advance.
    A3Kent's Avatar
    Different Gear
    May 2012
    1,066
    Can't you just go like for like? Seems the easiest way to me. Get the part number off it and go searching, probably eBay would be your best bet.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Jan 2012
    SW London
    794
    Any decent 6.5" woofer then mate. Doesnt haven't to be the factory spec but i'd make it as close to or the same RMS power as the factory one so the amp can handle it. The mounting holes are 4 equally spaced screws around the edge so no need for adaptors or anything. However the original one is a dual voice coil so has 4 wires (2 pos 2 neg) connected to it so u'll ideally want to find the same. This all depends on what kind of system u have mind.
    If u haven't taken it out, or any of the panels yet u need to remove the boot trim where the lock is first, take out the boot mat and parcel shelf, push the rear seats down and remove all the screws off the left panel and then it should come off. Theres a few of them and some are hidden under covers.
    Sep 2012
    24
    Like for like would be easiest I suppose, but I'd rather get something that's a bit more solid. Don't want to spend a fortune but happy to spend up to £100 for something that'll last a bit longer.
    Cheers for the reply
    Sep 2012
    24
    ...also, got the sub out no probs so that's fine.
    Had a look on amazon and eBay but struggled to find any 6.5" DVC subs that are 2x2 ohm. There was one rubbish one for a tenner, but although I'm saying I don't want to blow anyone away, I dont want it to blow up in a few days!
    Jan 2012
    SW London
    794
    Quote Originally Posted by nickjw2000 View Post
    As much experience as ive had with audio, different types of subs is not somethin im not clued up on. So with that in mind im wondering what would stop u using a single voice coil sub but then just attach both of the positives and negatives together to the terminals on the sub? Using a piggyback connector?
    2006 Audi A3 2.0 TDI S-Line 8P2 PD170 - Dolphin Grey Metallic - The problem child
    1994 VW Golf VR6 - Mystic Blue - The money thief
    VCDS User
    Sep 2012
    24
    That's a good question, I can't see it causing a problem but I don't know for definite...anyone??
    Sep 2012
    24
    Here's another question, feel free to tell me if I'm mental...There are plenty of good component speakers on the market, so if I bought a set of them could I just use one of the woofers and forget the tweeters and the crossover/s??
    It'd be easy to wire up and I wouldn't need to worry about mounting the crossovers or the tweeters. Fair enough I'd be wasting a good bit of kit and it might be a bit daft, but would it work?
    Dec 2012
    19
    Two problems really, the FS would be way out, being a Midbass not a Sub. In short, it won't behave like a sub
    Second, it won't be dual coil, so may present issues with impedance being different. I'd try and find out the impedance of the stock sub, and how it's wired (series or parallel) and it may be possible to find a 6.5'' sub that will work
    Sep 2012
    24
    Good shout with it being mid bass, hadn't taken that into consideration.
    Dec 2012
    19
    Are they definitely 2x2ohm? If so, I'll put good money on it being wired to show a 4ohm load, in which case you have a few options, such as a single DLS RW6 (expensive option but good subs) or this: 830946 - Peerless SLS 6.5 inch coated paper cone AL shorting ring in magnet system - Europe Audio
    For the money they brilliant
    Sep 2012
    24
    Nice one. Just checked a few reviews of the peerless and they get a good write up for a budget buy.
    The standard sub's definitely 2x2 ohm.
    Dec 2012
    19
    There is a budget option too, though I haven't heard anything about the quality of them
    MDS06 - Gradient 6 inch car subwoofer - Europe Audio
    Oct 2012
    Warrington, North West
    986
    Sorry to hijack, do all a3s have a sub in the boot?
    Sep 2012
    24
    Not sure about the older models to be honest. Mine's a 2006 S line.
    Turn up the volume a bit and stick your head in the boot, if there's a sub there you'll here it on the left hand side.
    Oct 2012
    986
    Ok mate, I take its behind the carpet then?
    Jan 2012
    SW London
    794
    Quote Originally Posted by Mikemc View Post
    The majority do. But i was shocked when i installed a system into a poverty spec 57 plate A3. It had no rear door speakers or sub. But yeh as said, put the bass up a lil and put ur hand on the left hand panel in the boot and see if u can feel some strong vibrations. Its mounted nearer to the boot
    Sep 2012
    24
    Yeah, behind the panel on the left. Here's a couple of links to check...
    Audi area: Audi A3. Disconnecting Sub-Woofer
    hi..audi a3 standard stereo..wheres the amp!?
    Oct 2012
    986
    Yea checked this morning it does indeed have one
  1. Audi A3 8L Sound-System (Non Bose) Upgrade Advice Please...
    By Lingo89 in forum In-Car Entertainment
    Last Post: 12th July 2011, 19:46
  2. Removing non Bose sub
    By Triple.O.G in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th March 2011, 19:15
  3. Removing non Bose sub in A4
    By Triple.O.G in forum In-Car Entertainment
    Last Post: 25th February 2011, 19:54
  4. A3 Non Bose Sub & Amp Install - Confused
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th December 2009, 15:01
  5. REPLACEMENT FOR BOSE SUB
    By jatbass in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 21:28
