JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
    Apr 2012
    59
    2.0 TDI 170 DPF Delete and EGR Blank ??
    Right guys been wondering if i should have this done as it has been worrying me looking at a big bill with new DPF ect ect
    Seems mine is re genning alot and the amber light comes on fairly regular even tho 95% of my time is spent on the motorway.
    So thinking its either new DPF or Delete along with EGR block and Map.
    Advice welcomed.
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    412
    I have looked into this myself with my 2.0tdi 140 as I am having a remap as a xmas present and even as I have had no issues with my dpf so far I have been told it's a good idear to have it removed at the same time.
    I've also had as far as I'm concerned a few different stories as to how this is done some say they remove the dpf some say they leave it on and reset the ecu to by pass it so I,m very weary of having it done so I asked my local Audi dealer and they told me that yes it can be removed but as my car is a 58 reg it will fail the mot because as the dpf is also part of the catalytic converter which by mot rules it must have and they have had quite a few people in the past who,s cars have come to them and have failed for this reason so I'm just having a superchip bluefin retune and leaving the dpf but if your car is only a year or so old having the dpf removed will be fine until mot time or just hope the mot tester doesn't look for the dpf under the bonnet because I again been told it ok to remove it
    because the undertray hides the dpf when the car is up on the ramp.
    Jul 2010
    Merthyr Tydfil, United Kingdom
    881
    Have you had the car scanned for codes since the light has been coming on?? Id start there and work out whats wrong. Normally the sensor on the bulkhead fails; they are about £50
    Not a go at you but I dont understand why people dont investigate why the DPF light comes on immediately. Prior to removing mine I drove the car in all manner of conditions, one period I was only doing 10 miles a day, and I never once saw the DPF light........
    if you are still worried then get it removed and remapped . I only removed mine because I was bored of the power lol
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    Apr 2012
    59
    why whats yours running rhys ?
    did you gut it or get a replacement pipe?
    Jul 2010
    881
    Quote Originally Posted by xtremedetailz View Post
    205bhp / 320lbs ft torque. I could have more but im happy with it at the moment........
    had a replacement pipe and passed the MOT with it back in September
    My Posh Golf
    Apr 2012
    59
    Where was the replacement pipe got from and how much was it ?
    Jul 2010
    881
    Mine was bought through Midland VW at a bit of a special deal as the pipe was a cancelled order.
    My Posh Golf
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    We do lots of these. We don't recommend the pipe as any inspections in future may cause you an issue. It's a perfectly fine way of doing it though. 205bhp is the power level I'd recommend too
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Apr 2012
    59
    how much to a fellow member ??
    Jan 2012
    Stockport, Cheshire
    748
    Hi, drive in drive out DPF delete, EGR delete, custom map is £600.
    Thanks, Rick
  1. tdi 170 DPF delete and Remap done but DPF light on???
    By Lewbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th May 2013, 21:02
  2. TDI 170 & DPF delete = MOT pass
    By jrsteeve in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd May 2012, 00:27
  3. Loss of power after first service (2.0 TDI 170 DPF)
    By Fleagle in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th March 2009, 07:41
  4. 2.0 TDI 170 (DPF) quattro Chip??
    By Keef in forum Diesel forum
    Last Post: 15th November 2007, 11:59
  5. 2.0 TDI 170 (DPF) Chip??
    By Keef in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th November 2007, 11:58
