Results 1 to 11 of 11
    Jul 2011
    Audi A3 8P Key fobs no longer unlocking car
    Hi all,
    My dads A3 8P (2004) 1.6 8v has developed a weird problem, both of his keys no longer operate the unlock system of the CCM. A read on VCDS doesn't show any obvious faults with the car and the lock function still works on both keys. The alarm sounds when the door is opened via the key as the immobiliser is active and only stops when the key is entered in the ignition barrel and the car starts.
    Anyone have any idea?
    leach76's Avatar
    Feb 2009
    sheffield
    304
    Check fuses mate,not sure if same but on mk4 golfs a mini 10 amp blade fuse used to blow causing this on the dash side fuse box
    Jul 2011
    Haven't checked them yet, but when my golf did this the other day I already had this issue... however thats complete CCM death with no functioning at all... I haven't came across anyone with this same problem yet . Will check the fuses eitherway though. Is there a fuse list anywhere?
    _G_
    _G_'s Avatar
    Jul 2011
    869
    had this a few years and the battery was on its way out and near dead... worth checking that too incase its not holding charge.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,622
    had this a few days ago, it turns out that when I was familiarising myself with VCDS, I selected Transport Mode to see what it did - it disabled the Remote Central Locking, as well as a few other bits ...worth a check.
    2009 A3 SB 2.0T DSG S line
    Apr 2012
    59
    I have got this very exact problem.
    Did you ever fix it ?
    Jul 2011
    Hmmm artimus, I have a feeling that it could be as you said perhaps... its something i'll definately check tomorrow! Car is still with the problem .
    Mar 2013
    I had this recently happen - dealer had to order a new fob and reprogram the car and fobs again. Problem appears to be fixed.
    Jul 2011
    Definately not transportation mode, . I note that in the measuring blocks... the ccm module recognises a binary 1 when the lock key is pressed on both fobs, but it does not recognise when the unlock key is pressed and the status indicator in vcds measuring blocks remain as 0. Appreciate any help!
    If you use the unlock button on the boot, it disarms the alarm but the doors still remain locked unless turned with the barrel.
    Jul 2011
    As per this thread: Key FOBs won't unlock - TDIClub Forums, user gvan had the same problem... replace the 2032 battery in the remote. Something so simple, . Just not enough voltage or whatever to send that signal!
    Apr 2012
    59
    Mine has had 2 new battery's and still nothing.
  1. Audi A4 replacement Key fob
    By Camus in forum General Automotive Chat
    Last Post: 16th July 2012, 10:13
  2. Newer audi key fobs info
    By dannyFR+tdi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2010, 11:17
  3. AUDI 2 BUTTON REMOTE ALARM FLIP KEY FOB
    By fallmonk in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th September 2009, 21:21
  4. How to programme your audi key fob ( Instructions )
    By shawshankuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2008, 20:38
  5. Audi S3 Key Fob replacement/spare cost
    By W14FEN in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th September 2007, 18:48
