Sky InsuranceChris Nott
    Oct 2009
    25
    amplifier trigger
    How is the amplifier switched on? I have an audi a3 sline 2007 with a chorus head unit with rear amplified.
    I am installing an alpine single din headunit and have fabricated a harness from quadlock to iso. Is the
    amp switched on via can buss as i cannot see a switched output from the chorus other than for the cd
    changer which i don't have?
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,870
    think there's a Blue remote wire in there somewhere mate!
    AndyMac is the resident I.C.E guru around here though, so if you can't find it - repost in the ICE section.
    2009 A3 SB 2.0T DSG S line
    Mar 2012
    369
    Sadly don't have quadlock or I could look this up on mine - at the risk of stating the obvious - is there a label on the Audi headunit showing the pinout? There is on mine, but that won't help as mine's the older ISO.
    Nov 2012
    17
    I used the feed from my jvc head unit that is for the aerial. Hope this helps
    Oct 2009
    25
    Thanks for the replies will repost on the correct section.
  1. ignition amplifier???
    By razor1974 in forum Detailing
    Last Post: 21st February 2006, 17:11
  2. 4 channel amplifier
    By tracer in forum In-Car Entertainment
    Last Post: 4th December 2005, 17:38
  3. JBL GTO 75.4 Amplifier
    By W8 Performance in forum In-Car Entertainment
    Last Post: 17th January 2005, 14:18
  4. 2004 S4 - Valentine One Triggered by?
    By mortonS4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd November 2004, 19:30
  5. Is it an amplifier????
    By RSAudi in forum In-Car Entertainment
    Last Post: 5th August 2003, 16:59
