AH FabricationsEM Tuning
Results 1 to 21 of 21
    Nov 2012
    38
    Tyre pressure for 225/35/19
    Hi guys, I have used the search function and found snippets of info' but no definitve answer.
    I'm running a 225/35/19 and I'm unsure which pressures to run them on? I appreciate that even the air volume in the tyre will be different but the pressure should be the same?
    Currently they are on the factory pressures of 36 front and 33 rear (3.2 V6), this seems to have increased the road noise somewhat.
    Can anyone shed any light on pressures to run?
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Not really a difinitive answer, but i run 34 front and 30 rear. Although over the last few months they dropped to the mid twenties! Thought the ride had been a touch more comfy of late!
    Nov 2012
    38
    Quote Originally Posted by TimG View Post
    Thanks Tim, I'll try those pressures and see how it goes.
    Are your wheels A8 Fat Fives 18x8.5?
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    i run 30psi all round
    Donny_DJ's Avatar
    Oct 2010
    Surrey
    119
    I run 40psi on my 18" S-Lines
    :O
    Audi A3 2.0T FSI S-Line Special Edition, 2006, Avus Silver. Eibach Pro springs, H&R 10+12mm Spacers, AMD remap, MY11 Rear clusters, Flat bottom steering wheel, Chrome S3 SE Gearknob, R8 Oil Cap.
    I mix house music: http://soundcloud.com/donny_dj
    Instagram (cars n stuff): http://instagram.com/donny_dj
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    934
    I run 36 front, 33 rear
    TimG's Avatar
    Feb 2004
    South Coast
    932
    Yes A8 8.5x18's
    Quote Originally Posted by Donny_DJ View Post
    :O
    That's a lot of pressure!
    N8
    N8's Avatar
    Kowalski Details
    Jul 2007
    Salford, Manchester
    17,128
    Between 32-36 I'd say
    Nov 2005
    UK
    586
    I'm running 225/35 19's on my S3 SB and I run them at 39F 38R which is perfect for me......I actually did a bit of research and found out the standard pressures for the RS3, as that runs this exact size of tyre as standard ( on the rear anyway, and 235/35 19 on the front and is roughly the same weight ), and that is 41F and 40R ( but those were too harsh for me ).
    audicruiser's Avatar
    Audi Heaven
    Somerset
    1,861
    Yes A8 8.5x18's
    No, thats right... We run 42psi in the fronts on our 2010 170 TDi S-Line which is what the sticker states. The lower the profile, the higher the pressure to compensate.
    Scott
    Audi A3 Sportback 2.0T Quattro S-Line 2007 8P2
    Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, iPod, Auto Lights & Wipers, Interior Light Pack
    Nov 2012
    38
    Thanks for the response guys, I'll see how it drives with the standard pressures and maybe drop them slightly to see if road noise changes.
    shady-ninja's Avatar
    852
    40psi is an accident waiting to happen.
    you will lose alot of traction in the snow and wet
    and lose some traction in the dry.
    when you finally decide to put in the correct psi
    the try will produce a drone like noise.
    Djwoody's Avatar
    Nov 2011
    Middlesbrough
    325
    I have just upgraded to the same size tyres: 225/35/19.
    Would you say 35 PSI all round if the best for my 2008 A3 2.0 TDI 170?
    Nov 2012
    7
    Hi Guy's,,,This is what I have been looking for after fitting 235/35/19 on my A4 3.0 Quatrro, Trouble is I cant get rid of the tyre pressure warning on my dash, that is after putting in 38 psi all round !!
    Any idea's
    bez101's Avatar
    Jul 2008
    8,420
    did you swap the sensors from your old wheels to the new wheels ?
    Nov 2012
    7
    Sensors !! No. I didnt see any. Ooops am bad !
    Nov 2008
    389
    What year is your A4?
    Work: A3 Sportback Black Edition 2.0TDI Home: A4 Avant 2.0 TDI Quattro S-Line
    Nov 2012
    7
    Quote Originally Posted by phil_w View Post
    Its a 56 plate 2006 3.0 Quatrro convertable
    Nov 2008
    389
    Yep that year of A4 will definitely have had sensors on each wheel unlike the new A4s that just use the ABS for tyre monitoring. If the controller can't communicate with the sensors that'll probably be why it's whinging :-(
    Nov 2012
    7
    Cheers for that Phil, That would explain things, do you know if the sensors are transferable or can I disable the warning ?
    Many thanks for your help
    Dave
    Nov 2008
    389
    Never seen them in the flesh but I'm assuming that they're part of the valves themselves on the old wheels - but should be able to be moved. Not sure on disabling it on the car but probably possible with a VCDS cable. Sorry to be vague.
  1. Tyre Pressures for 225/40/18 tyres
    By sponger007 in forum General Technical / How To
    Last Post: 12th January 2012, 22:10
  2. tyre pressures for 225/35/19????
    By millwrx in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th October 2010, 00:53
  3. Tyre Pressure for 225/40R18 tyres
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th October 2008, 17:18
  4. Tyre pressures for 225 35 19 tyres on my 2000 S3
    By brucelee1973 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th March 2007, 11:50
  5. Tyre Pressure Help 225/40R18
    By necroeire in forum General Chat
    Last Post: 13th November 2006, 18:21
