Sky InsuranceAH Fabrications
Results 1 to 7 of 7
Thread: Parking sensors
    Oct 2012
    Warrington, North West
    959
    Parking sensors
    Is there anyway to get the radio to reduce its volume whilst reversing? I've noticed other family members card do this, tried messing about with buttons yet can't find anything?
    SPARTAN91's Avatar
    RED FIVE STANDING BY
    Zookeeper Champion
    Nov 2012
    NORFOLK
    404
    Just a thought have you tryed increasing the volume of the sensors beep via the DIM on the dash
    Oct 2012
    959
    Parking sensors
    How do I do that? Sorry not had it long, do you mean DIS?
    SPARTAN91's Avatar
    Zookeeper Champion
    Nov 2012
    NORFOLK
    404
    Yer sorry DIS if you have the factory audi fit parking sensors as per my 58 reg facelift (white colour DIS) red on pre facelift then you need to access the menus via the reset button on the bottom of the windscreen wiper lever and use the up and down button on the end of the lever to find parking aid menu you can also adjust wipers/windows/door and exterior lights and turn signals via this menu.
    It took me a while to learn how to use and find things in the menu but you will need to know how to put the wipers in the service mode if you need to change the blades as you cannot lift the wiper arms up fully on facelift A3
    Hope this helps a little
    Oct 2012
    959
    Parking sensors
    Well I changed my blades the other day, I have the red menu, can I still access this stuff?
    SPARTAN91's Avatar
    Zookeeper Champion
    Nov 2012
    NORFOLK
    404
    Yer the facelift A3's like mine have a different wiper desgin so they so they need to be moved via the DIS menu.As for the access to the
    your menu I could not be 100% sure as I can only tell you from my point of view as this is my first A3 so hopefully you can get an answer from some one who has the same red menu but I cannot see why access to the DIS's should be different.
    Oct 2012
    959
    Parking sensors
    Well to get mine in service mode I had to turn ignition on off then on and the press wiper or something along those lines, my dis doesn't give me any options to change stuff just to change the speed warning, and the what computer 1 and 2 show
  1. Parking Sensors
    By Masterm8fo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2005, 17:13
  2. Parking Sensors
    By god_thats_quick in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2004, 19:00
  3. Aftermarket Rear Parking Sensors
    By hfu in forum Detailing
    Last Post: 15th April 2004, 14:15
  4. Aftermarket Rear Parking Sensors
    By hfu in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th March 2004, 13:02
  5. Retro fit Parking Sensors
    By 18ME in forum General Technical / How To
    Last Post: 17th June 2003, 15:49
