Likely 66.6 to 57.1 you want, but depends on the wheel you're trying to fit. Might be 75.1mm, or just about anything in between, depending on the make of wheel.
I got some rs6 reps and they seem to be around 65mm not sure as I cant get the vernier gauge inside, I need to find the right set now as the ones i ordered were 75mm to 57. Anyone had any luck finding them?
