Chris NottBadger5
Results 1 to 25 of 25
    Dec 2012
    51
    A3 problem that even the main dealer cant sort out
    Hi , looking for a bit of help here from anyone who might have experienced something similar with there Audi. I bought my third A3 from Arnold clark and after a week discovered on turning left on low speeds a rubbing sound coming from the off side front wheel area. The car has been into Arnold clark an amazing 8 times about this they have done a wheel bearing cleaned up brake calipers and put copper grease on them to no avail . After a heated visit to the service manager at the garage they agreed only the main dealer could fix it but after two days with Audi they havent managed to get to the bottom of the problem and advised to let the fault develop so that they can identify it when its totally knackered!Any help would be welcomed as im at the end of my tether wih this many thank
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Couple of things.
    Brake caliper dust/heat shield and, this may sound silly, but check the windscreen washer bottle is not low in water.
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Where are you based? If you're local we'd be happy to check it out
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Dec 2012
    51
    Angry
    Quote Originally Posted by MrLapou View Post
    Couple of things.
    Arnold clark cleaned up the brakes and calipers and have adjusted the heat plate , washer bottle is full the next stage we are at is getting the caliper , disk and pads changed if this doesnt work ive no idea !
    Dec 2012
    51
    Thanks bud but im in Glasgow
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    476
    Okay here me out, this will sound Bizarre but try checking the engine cover - the big plastic cover under the bonet.
    Mine was making a noise the other week after it had being returned from Audi, I thought its just been in to Audi...
    Looked under the bonnet and they hadn't clipped the cover down correctly :S Not too sure what it was catching on but when i full locked left it made a rubbing noise.
    Hope this resolves the issue, and if not sorry for getting you out in the cold :D
    Dec 2012
    51
    cheers bud , getting out in the cold isnt a prob if it sorts this issue out honestly its getting like chineese torture
    Jul 2010
    Merthyr Tydfil, United Kingdom
    874
    Steering rack? Anti-roll bar bushes??
    Now a happy owner of an A3 Sportback S Line 170 TDI
    My Posh Golf
    A3Kent's Avatar
    Different Gear
    May 2012
    1,065
    Bearing on top of the suspension mount? My front passenger side one was making a knocking/pinging noise at low speed (when parking etc). Audi sorted it with a new bearing.
    09 Audi A3 2.0 TDI 170 S-Line SB 8P3
    - Full Leather - LED DRL's - BOSE - Cruise Control - RNS-E Mk2 - AMI - Bluetooth - Folding Mirrors -
    VCDS owner - A3 Grille Install Guide
    Dec 2012
    51
    Quote Originally Posted by Rhyso View Post
    Have you had problems with these , the noise is like a rub which is not continuous when turning left ?
    phil76's Avatar
    Feb 2008
    SHEFFIELD
    556
    Is it rotational ? if it makes a rubbing noise when turning left does it increase with noise or get quicker ?
    Phantom Black S3,Giac stg 1,Evoms intake,Lamin-x
    (to do list,update signature pic)
    Dec 2012
    51
    A3 problems
    Quote Originally Posted by phil76 View Post
    Yip its rotational , sounds more like a rubbing noise it does increase on speed variation but it is more noticeable when driving away from a parked position turning left . Thanks for any help you can give !
    Dec 2012
    51
    Sorry it gets quicker with speed ,increases in noise when done at low speed
    Jonathaan's Avatar
    Diesel Power!
    Nov 2012
    Leeds
    476
    Im guessing the engine cover was all OK ?
    Dec 2012
    51
    Quote Originally Posted by Jonathaan View Post
    HI mate checked it out and it all seems tight !
    Jul 2010
    874
    Quote Originally Posted by jimick View Post
    no i was merely offering suggestions
    My Posh Golf
    Aug 2010
    1,540
    is there an anti viabration ring on the driveshaft? (looks like a dohnut halfway up the shaft) is that in place?
    Oct 2009
    20
    Try checking the CV joint rubber gaitor is making the noise. My dad's mazda 2 was making noises whilst turning, so jacked it up and checked the usual suspects and nothing until put it on full lock and turnd it and fount the gaitor was the issue.
    Aug 2010
    1,540
    ^^ could be. on full lock the folds in the gaitor contact each other and can make a creeking/squeeking noise. doubt youd be able to hear it in the cabin with the windows shut?
    Dec 2012
    51
    what is the anti vibration ring ? Its not something that has been mentioned by anyone who has looked at the car. The sound is like a hard rubbing noise and you can feel it slightly through the steering wheel.
    S3 Owner
    Sep 2009
    Midlands
    123
    Suspension bearings, there is a technical bulletin regarding these (I had mine done not long ago).
    Dec 2012
    51
    Angry
    Quote Originally Posted by taylorc View Post
    Honestly , what car did you have it done on ? and what year ? The problem with mine has ment the car spending two days at audi and no one there mentioned anything about this
    Dec 2012
    51
    Just had wheel bearing ,brake disks , pads and caliper changed and guess what no difference Please someone out there must know something about this !!!!!! HEEEEEEEPL
    Dec 2012
    51
    Dont think it would be this as the noise is rotational noticed more driving slow
    Dec 2012
    51
    Quote Originally Posted by murran View Post
    Hi mate there is nothing on the shaft like a donut ?
  1. A3 problem that even the main dealer cant sort out
    By jimick in forum The Welcome Section
    Last Post: 6th December 2012, 23:04
  2. 2.0 tdi s-line 170 bhp running problems help because Audi main dealer CAN'T
    By DirtyDiesellee in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd July 2012, 18:50
  3. 1st Service at the main dealers soon, help?
    By sat1983 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th October 2007, 13:08
  4. Replies: 2
    Last Post: 16th May 2005, 19:52
  5. the car dealer or is that stealer
    By delkhela in forum The Welcome Section
    Last Post: 22nd October 2004, 02:22
