Results 1 to 15 of 15
    Dec 2012
    23
    Coming/leaving home not working
    Hi!
    I have just bought a 2005 A3 2.0 TDI DSG and I´m wondering how the coming/leaving home function works. I have a button below the light switch with the symbol of a clock and a light, but nothing happens when I push it. -I´m guessing it should switch a red light on/off right?
    Any tips for troubleshooting?
    Thanks!
    Sandra's Avatar
    MODERATOR
    Sep 2010
    Scotland
    15,323
    Hi, welcome to audi-sport.net. Have a read through the faqs threads at the top of this section, lots of useful info in there. Enjoy the forum. x
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,420
    you turn it not push it
    turn it on get out the car lock it
    only when its dark tho.
    Boon's Avatar
    Sep 2012
    South East Kent
    405
    First I'd remove the light switch - turn it clockwise from the off position about halfway between the sidelight and off position while pushing the whole switch in, then the whole switch unit will come out towards you - it requires a little bit of a knack but you'll soon get it!
    Then you will be able to see if there is a connector to the rear of the little switch for coming/leaving home - if not then its a retro fit switch - if there is then it could be a wiring problem or may need activating for whatever reason with VCDS
    It will be possible to get it working either way but hard to diagnose
    Do you have a light sensor in the windscreen behind the rear view mirror?
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Quote Originally Posted by master83 View Post
    Hi!
    Thanks!
    That's not the dial brightness adjuster is it?!
    I didn't think that there were any buttons for the coming home lights and they were activated through DIS? And only if you had the auto headlights?
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Dec 2012
    23
    This is the switch I have (but I have two fog light options)
    and yes, I have light/rain sensor.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    898
    Gotcha! Never seen that before, looks like you're right! No idea then. :/
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,606
    Have you tried it in the dark? The coming home/leaving home lights only work in the dark.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    Dec 2012
    23
    Does it have to be dark to activate it via the button?
    Anywho: It's always dark here now up north :/
    Jay.Ing's Avatar
    Jun 2008
    Southport
    257
    Does the red LED light up when you press the Button? Do you leave your switch in auto? and do your autolights work?
    2012 A3 Ibis White SportBack Black Edition 140
    Mods so far: H&R 50mm, Rain Light Sensor, RNS-E, Cruise control, Interior OEM LED mood light, OEM LED number plate lights, OEM LED Puddle lights, OEM LED Footwell Lights, tear drop wiping, Beep confirm on close, pressed plates, HHA & TPMS.
    Red A4 Black Edition 150Tdi.... On order!
    Gone But Not Forgotten....
    2011 A1 Black Sline 106
    2006 A3 Red Sline 140
    Dec 2012
    23
    No the button does not light up.
    I have the button on Auto.
    when in auto, the xenons are on - not sure how to test if the autolights are working.
    No error codes in vagcom either.
    jb0o's Avatar
    Feb 2009
    North East, UK
    2,606
    Strange.. The red light should come on or go off when pressing the button, regardless of being dark outside.
    Give the autolights a test by putting a peice of paper on the windscreen over the sensor, just underneath the rearview mirror.
    Dec 2012
    23
    I will try with a flashlight later tonight. also check in VCDS if the feature has been turned off for some reason.
    Feb 2004
    Borders, Scotland
    404
    Maybe someone's had the switch out and not reconnected the wires it at the back?
    Dec 2012
    23
    It was disabled in vagcom.
  1. Coming/leaving home lights and LED number plate bulbs?
    By C20JCK in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2011, 18:51
  2. coming/leaving home question
    By Vex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd December 2010, 08:06
  3. DRL and Coming/leaving home lights
    By L7 BRY in forum VCDS (formerly VAG-COM) forum
    Last Post: 15th July 2010, 16:32
  4. Retro fit rain sensor and coming leaving home
    By Hasse_S4 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 27th March 2008, 16:00
  5. Coming / Leaving home add-on
    By imported_andersov in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd April 2005, 06:25
