Chris NottSky Insurance
    Oct 2012
    26
    Coding in the Plymouth/Cornwall area??
    Can anyone recommend a garage/specialist in the Plymouth area that could code a MFSW/RNS-e. Used the search facility and google but no joy apart from RK Engineering (Hoped to find someone closer if possible to the Plymouth area).
    Cheers Pablo
    Fossie
    Rhubarb Triangle
    3,961
    If you use the vcds user map you will see a member called RickH in Liskeard.
    Send him a PM to see if he can help.
    Oct 2012
    26
    Is it a simple case of connecting and selecting the required options? Would most VCDS users know what to do??
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Pablo Pirate View Post
    If you have fitted the mfsw and rnse then there are loads of threads about coding. I don't know which search function you used but anyone with vcds can do it easily !
    Oct 2012
    26
    Initially I didn't search for VCDS coding (As I don't have this facility) I searched for Audi specialist in the Southwest/Plymouth area.
    Fossie
    Rhubarb Triangle
    3,961
    Pablo, of course you have the facility ! It is part of this forum !!!
    VCDS (formerly VAG-COM) forum
    Click on the map, enlarge to your area and click on a flag !
  1. TIG Welding and fabrication service in the Plymouth area
    By S321BAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2012, 19:12
  2. Replies: 1
    Last Post: 20th May 2012, 20:13
  3. anyone out their in the plymouth area that could plug me in and help me with vag com
    By cominatcha in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd March 2012, 10:24
  4. Anyone in the plymouth area with VAG COM ?
    By frenchman in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th August 2008, 19:18
  5. Part code for the 18" OEM RS TT
    By Aky in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2007, 07:41
