AH FabricationsJMB Retrofits
    Dec 2011
    MIDLANDS
    241
    Question A4 wheel fitment on my A3
    hi guys ive seen a set of alloys i like from an A4.
    The size is 18 x 8.0 with an offset of ET47.The centre bore is 66.5
    will i need spigot rings?
    will these fit under my rear arches as my A3 is lowered?
    i currently have standard 5 spoke s line wheels with 10mm spacers on the rear.
    i am puzzled with the offest and wheel width so any help is greatly appreciated
    A3 2.0TDI S LINE, Awesome remapped, ITG, Milltek, S3 Front + Rear bumpers + Sideskirts, Cruise and slammed on coilovers. NO SMOKE - NO POKE!!!!!
    BigWillyStyle's Avatar
    Aug 2012
    566
    Bore for an A3 is 57.1mm i believe and the ET should be between 45-50. What is the PCD? 5x110 or 112?
    Jul 2011
    106
    Re: A4 wheel fitment on my A3
    That offset is fine, and the rears will fit without the spacers. As BigWilly said, our hubs are 57.1, so you will need rings. And all A4s back to the B5 gen are 5x112 so that won't be an issue. I'm guessing that with a larger hub bore these are off a B8?
    Dec 2011
    MIDLANDS
    241
    2012 plate A4 mate. so i will need spigot rings from 57.1 to 66.5, but the offset and rim width are fine?
    Aug 2012
    566
    Offset and width is fine. I have 18x8.5J on my A3
    Jul 2011
    106
    Quote Originally Posted by WALTO TDI View Post
    Yes :thumbup:
  1. wheel fitment
    By chrisa4quat in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th June 2006, 22:26
  2. Wheel Fitment Question & Tyre & Lowering
    By ScottyBoy in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th June 2006, 16:27
  3. wheel fitment
    By shresh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th April 2005, 16:11
  4. wheel fitment
    By imported_jasmine in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th November 2004, 20:37
  5. alloy wheel fitment
    Last Post: 6th October 2004, 14:21
