EM TuningAH Fabrications
Results 1 to 12 of 12
Thread: Egr
    Oct 2012
    492
    Egr
    Do I go for egr delete kit or just a £3 blank plate on my 140 tdi ?
    dex140's Avatar
    Dec 2009
    190
    Blanked mine on my 140, ran a lot smoother at idel, defo worth the £3 but you will get the eml which you will have to get mapped out or just put up with as i did! When i came to sell i took it off and EML went out! Still need to do this to my 170!
    Boon's Avatar
    Sep 2012
    South East Kent
    411
    Mine run like a bag of crap when I blocked mine off... Erratic idle and wasn't smoove to drive...
    Just removed it and put the EGR back as normal & would like it to be mapped out at some point
    dex140's Avatar
    Dec 2009
    190
    Mine was quite the opposite! I dont see how it would run worse when there is no exhaust fumes being reciculated
    Boon's Avatar
    Sep 2012
    South East Kent
    411
    Because the engine management is not receiving the same data as is was requesting...
    Can't remember the actual numbers but using VCDS the EGR at a determined RPM was requesting say, 600mbar or whatever it was and the actual reading, because it was blocked was zero it caused the error...
    I can look up the actual readings and what it was measuring (pressure or contaminates I.e. fumes) over the weekend if anyone wants to know but currently away from both car and VCDS...
    Oct 2012
    492
    Dex where did you blank yours just one side and did you put a gasket on the blank? I talked to awsome and they said they will map out the light for £30 on top of the £150 remap
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    Gents, don't waste your money on a fancy kit for EGR delete. Physically, all you need is a plate to block the circuit. When we get them in, we remove the whole cooler assembly etc to improve reliability - less chance of leaks etc.
    The important thing is to get it mapped out. And that means properly - not just disabling the warning light! The ECU will then fuel accordingly as it knows there is no EGR flow.
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    dex140's Avatar
    Dec 2009
    190
    As Rick says i just used a blanking plate on the side of the EGR, i belive you can also blank at the other end of the pipe.
    Oct 2012
    492
    I talked to awesome gti about mapping the egr light out and asked them if the £30 they charge is to map out the egr aswel as the light and they gave the impression that all that needs doing is the light and that it makes no difference to fuelling or anything else ?
    Jan 2012
    Stockport, Cheshire
    748
    The EGR control maps should be changed. If not, ECU will be expecting airflow that won't happen and so will therefore be in a state of constant correction. You can just disable diagnosis and it will work, but it's not ideal.
    Rick
    Oct 2012
    492
    Quote Originally Posted by Rick @ Unicorn Motor Dev. View Post
    Rick
    what do you cbarge for remap and egr software removal rick
    Oct 2012
    492
    Right ordered the blank plates of eBay so I have little knowlege of doing this kind of thing so is there a picture of exactly where I put the plate on my bkd 2.0 tdi
  1. The EGR system (Exhaust Gas Recirculation system)
    By imported_jamesgraham in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2007, 08:54
  2. EGR Blanking cap
    By james0808 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st December 2006, 14:45
  3. Blanking plate for EGR valve. Does it work wonders
    By Holywood in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2004, 15:12
  4. EGR Cleaning
    By MartinReid in forum Diesel forum
    Last Post: 7th May 2004, 10:06
  5. EGR valve
    By Pookie in forum Diesel forum
    Last Post: 29th July 2003, 16:11
