Volks AutosSky Insurance
Results 1 to 15 of 15
Thread: RS4 Fuel Valve?
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    RS4 Fuel Valve?
    Been looking at stage2+ Revo and on here people seem to say i need a RS4 Fuel Vlave? Is this true?
    If so whats the part number so i can order on at my local Audi?
    I've got everything else.
    Jan 2009
    184
    i think you will need the RS4 Fuel Valve if you go Stage 3 but at £40 or so it is probably worth doing anyway
    Now: 2009 S3 8P3 DSG. Mods: Revo Stage 1, Cruise control, LED interior lights upgrade, Rear DRLs...
    Previously: 2001 AMK S3, Silver, Revo Remap, Milltek DV, KW Springs & Shocks, H&R ARB.
    olethalb's Avatar
    Aug 2012
    312
    RedDejavu's Avatar
    Feb 2011
    Bracknell
    1,332
    not need untli stage 3 as said above
    Be patient. English is tough.
    Now:
    61 Audi S3 BE S-Tronic Ibis White: Build Thread.
    / Black Edition pack (SatNav, Bluetooth) / Parking Sensors / Tinted windows / piano inlays and finish / Cruise Control / Interior light pack /
    /Mods: REVO Stage 2+: Revo Intake / Milltek Resonated TBE / LOBA HPFP/ GFB DV+ / Crystal Clear H11 FOGS / Black roof + spoiler vinyl wrap / H&R Anti-roll bars / Superpro ALK /
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,790
    RS4 Fuel Valve?
    As above its not essential until Stg3 and above.
    If you're going to do that then it's worthwhile and some claim benefits at Stg2+ but mine was fine without.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Quote Originally Posted by S3Alex View Post
    So there's no dip in power at the 5k mark when giving it the beans with the standard one? Would the revo stage 2+ benefit with it or would it just be pointless waste of money? Not going to go above that stage.
    olethalb's Avatar
    Aug 2012
    312
    i fitted mine to try and cure the massive flat spot between 5.5 and 6k revs but suspect it's my intank pump dying so thats next. i'll be hoping to get nearer the 400bhp with mine soon though so is worthwhile for me anyway.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    Quote Originally Posted by olethalb View Post
    you'll never achieve 400 with oem turbo.
    part costs 40 but it's the fitting labour that's probably going to cost 3x that as it's right under the intake manifold.
    i'm getting mine fitted same time when i'll do uprated clutch kit.
    as said above depends on your tune will you feel the flatspot above 5k rpm's or not on stage 2+.
    i tried different setups and with one i got a massive flatspot over 5k rpm's. but with current setup i'm fine.
    there are threads on the internet with data from the both stock and rs4 fpr showing that rs4 fpr gives closer pressure to the requested one.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    olethalb's Avatar
    Aug 2012
    312
    i have hybrid k04 and wmi, took me 10 mins to fit with no special tools.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    sorry mate. didn't know that :D
    would you like to share more info about that turbo ...:D
    olethalb's Avatar
    Aug 2012
    312
    it's from turbo technics:
    High flow K24 Compressor wheel (from an RS4) modified to suit
    Re-profiled compressor housing
    Uprated 360 degree thrust kit fitted
    Lightening of turbine wheel for quicker response
    fitted AEM WMI monday but haven't hooked it up yet, waiting on intank pump upgrade then hook it all up on remap day.
    obviously got 3" decat, milltek cat back, custom fmic, S3 injectors, relocated DV, auto tech and PCV fix to support.
    and i was referring to the pressure valve taking 10 mins to fit with no special tools bar some 12mm ID hose to locate the new valve before tightening it down.
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,386
    very nice.
    it's going to be a rocket once set.
    well i guess if you're skillful enough you can do it in 10 mins.
    i know i would end up with parts all over the engine bay. lol
    just like when i was a kid, every rc car i had to dismantle but when i put it together i got excess parts
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,790
    RS4 Fuel Valve?
    Quote Originally Posted by DJ-S3 View Post
    I would say with what you have in mind that its a worthwhile and very cheap upgrade.
    The stock regulator is working near its limits with 360-370bhp and its such a cheap thing that its a no-brainer.
    The AEM kit is very simple to set up and works well with an uprated intercooler to keep temps down.
    Mine starts at around 0.8 bar and runs through to max out at 2 bar.
    You would want yours to reach full flow by around 1.6bar I would think.
    The ECU limit for boost is 1.7 bar but I doubt your hybrid would sustain that so you shouldn't need a boost controller and further software changes.
    Hope you enjoy it!
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    4,790
    RS4 Fuel Valve?
    BTW....if your car is an S3,the stock LP fuel pump is ok until 440bhp and you would need a lot of extras to go beyond that in any case.
    DJ-S3's Avatar
    Apr 2009
    Wakefield
    683
    Right cheers
  1. RS4 Fuel Valve?
    By mjr901 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2012, 17:19
  2. Anyone fitted RS4 fuel rail after stage 2+ Revo?
    By warren_S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th September 2011, 09:29
  3. Autotech Pump & RS4 Fuel pressure regulator fitted @ Star Performance = :-)
    By akash_sky1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th December 2010, 17:30
  4. B5 RS4 FUEL MPG ADVICE PLEASE
    By rs4driver in forum RS4 Forum (B5 and B7 Chassis)
    Last Post: 15th February 2007, 21:01
  5. exhaust valves on S4 and RS4
    By terminator in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th February 2004, 00:15
