Monster MotorsportVolks Autos
Results 1 to 13 of 13
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    S3 - Stage2+ Boost Concerns
    Hoping I can get a 2nd opinion with regards to what I'm seeing in my car's boost logs as I've already taken this up with my local tuner.
    Below is a 3rd into 4th gear pull (letting the S-tronic box shift at the limit) view of requested v.s. actual boost as well as N75 duty cycle. The big request/actual dip towards the end is the gear change and is a concern itself as the car is jerking on change like its losing power momentarily.
    As you can see the car struggles to meet the requested 1.5 bar and takes a heavy dip in boost in the last 1000 rpm before the limit. At the same time as this dip begins N75 values shoot up.
    Does this look normal for a 2+ car? I'm especially concerned about what appears to be the N75 struggling to retain boost from 5000rpm onwards. The car is running the Revo v12 non-linear throttle map, custom 76mm downpipe, EVOMS, Autotech HPFP internals
    EDIT: The full logs are available here - logs OR Zippyshare.com - LOG2(1).xls
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    The K04 is pretty well maxed out on Stg2+,and from what I understand cannot deliver enough flow for maximum boost at max rpm.,and I'm not surprised that the wastegate controller is struggling to maintain boost.
    Why not drop Revo Kev or Carl a line and get the advice from them.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Well I managed to get my hands on a "healthy" 2+ S3 S-tronic boost log.
    Compared to my graph posted earlier (bottom one in the pic above) it seems that dip in the last 1000 rpm before shift is the norm, but I'm still underboosting a fair amount through the entire rev range. I did try contact Revo HQ, but I keep getting referred back to the SA dealer.
    Ex: 1978 VW Beetle
    S3Alex's Avatar
    Rarely neutral
    Dec 2008
    5,354
    I would actually email Carl and Kev the files and go from there.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    The other worrying factor I still have this super long/noisy startup since I went Stage2 that I'm wondering if it isnt related:
    Ex: 1978 VW Beetle
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    what Boost setting are you running?
    yes it seems that it's underboosting.
    s3 Ibis White ... Build Thread
    / Black Grill / FbMfSw / Sunroof / Hill Hold / Armrest / Black Leather-Alcantara interior / Rear Parking Sensors / Heated Seats / Folding Mirrors / Cruise / Rns-e mk2 // ttrs-Brembo Brakes / 12mm spacers / Forge Short + Side Shift / 42dd's / ITG CAI / GfB DV+ / Forge Catch Can / Milltek TBE / Forge Twin IC/ Autotech HpFp / H&R ARB's / WALK / KW v3's / RS4 fpr / Loba&Sachs clutch / Revo Stage 2+ / ...
    Silky-S3's Avatar
    Is loving his new 8V S3!
    Jan 2009
    1,389
    Is this the "new and inmpoved" revo map? I had boost and s-tronic issues with it. The car is prefect on the old revo map, like a totally different animal. Revo sorted me out back on the old map now
    S3 8V Sportback Stronic, Estoril Blue Crystal Effect, Black Interior, Adaptive Cruise with Stop & Go & Pre Sense, Super Sports Seats with Electric Lumber, LED Headlights, Interior Lighting Pack, Hill Hold Assist, Privacy Glass, Comfort Package, Technology Package with Audi Connect, Advance Key, Folding Door Mirrors, Extended Mono.Pur Interior, Front and Rear Parking Sensors, Audi Sound System.
    Build Thread Here!
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by S. View Post
    Boost 7, Timing 3, Fueling 7 (both mine and the other S3 were running that)
    Quote Originally Posted by Silky-S3 View Post
    I thought that was the issue as well, but again both mine and the other S3 are running the "new and improved" v12 map.
    If possible would you be able to get hold of your logs for the v12 map?
    Ex: 1978 VW Beetle
    poli84's Avatar
    Nov 2010
    Melbourne. Australia
    430
    Apologies for not sending my logs, I had the 2+ tune loaded last week but due to timing, we haven't run any logs as of yet.
    I've got the new and improved tune and I am not sure that i like it, doesn't feel agressive enough.
    Think I will have the old 2+ file loaded and I will get some logs. Would be interested to do some logs on the "new" tune first though before reverting to the old 2+ file.
    How do you find the linear throttle? Do you think you will keep it?
    Also, regarding your cold long start, I'm so glad you brought that up.
    Since installing the HPFP and 2+ tune, my cold start is as long as yours.
    Is this normal, are other Revo 2+ cars experiencing this also?
    MY10 S3 Sportback - 6Sp Manual - Sprint Blue
    REVO Stage 2+ /
    Forge Twintake / 3" Miltek Hybrid DP/​ Autotech HPFP
    Bilstein PSS10
    / H&R 10/12mm Spacers / BFI Dog Bone /EBC Yellowstuff
    BUILD THREAD
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Quote Originally Posted by poli84 View Post
    Had v12 linear when I went Stage 2 and wasn't impressed with it at all. Made the car feel very lazy, but I can see how it would be an advantage for manual cars in terms of getting off the line. When I went 2+ the car felt more alive and torquey, but now I can see that this was a result of swapping out the linear map for the non-linear one.
    As for the long cold start, it literally started the morning after the v12 Stage 2 tune so I'm definitely leaning towards it being related. If you do go back to an older version (v10 seems to be the most popular) please let me know if it sorts that out.
    Unfortunately I'm about 300km away from my tuner so swapping maps isn't quite as simple
    The headoffice for Revo SA has suggested everything from a leak to a bad turbo to using EVOMS rather than ITG for my car's failure to meet the requested boost in the same fashion as the "healthy" graph I posted earlier. So where I should start looking is still the question...
    Ex: 1978 VW Beetle
    S.
    S.'s Avatar
    Mar 2009
    N/A
    1,422
    well i would say intake shouldn't be a issue because others are running evoms on stage 2+.
    what type of dv do you have? check the PCV as they are known to fail. and check all the jubilee clips on the intake if they are tight enough.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    My thoughts exactly. I've only heard good things about the EVOMS and claims of superior flow rates.
    Got the piston type Rev H DV, was on the car from stock being a 2010 model. PCV wise I'm running the Revo (BSH copy) fix, but have swapped back to the stock one and the same boost issues persist. Will have a look at the intake again to see if it's fitted properly.
    Ex: 1978 VW Beetle
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    Revo HQ has indicated that there is a recent patch available for S-tronic equipped cars with certain ECU codes (my AQ revision being one) so I'm going to have that flashed as soon as I can get to my tuner or visa versa.
    Hopefully this sorts the issue out, but I'm still leaning towards a hardware issue.
    Ex: 1978 VW Beetle
  1. Logging turbo boost with VAG-COM
    By Ram in forum VCDS (formerly VAG-COM) forum
    Last Post: 26th January 2009, 22:23
  2. Boost Limit for 1.8t (S3)
    By lost_it in forum Tuning
    Last Post: 23rd July 2003, 14:03
  3. turbo boost?
    By edwin98 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 14:06
  4. Max Turbo Boost Revo settings
    By MushroomMan in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th July 2003, 14:54
  5. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
