Volks AutosMonster Motorsport
Results 1 to 16 of 16
Like Tree1Likes
  • 1 Post By Staz
Thread: Outside temperature gauge reading 5 degrees too low?!?
    A3 Sportback 2.0 T FSi
    Jul 2011
    Congleton
    67
    The outside temperature gauge has suddenly started reading exactly 5 degrees to low, anyone got any ideas?
    It moves up and down as the weather changes but always around 5 degrees out.
    Thanks in advance for any suggestions.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Did you resolve this issue? Mine has suddenly started reading too high. It's was showing 36.5 degrees this morning!
    8P2 S3
    Jul 2011
    Congleton
    67
    No its going in to Crewe Audi for service next week and its on their to do list. I will let you know if they give me an answer.
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,843
    Quote Originally Posted by Staz View Post
    that's only 2.5oC, about right for snow melt.
    2009 A3 SB 2.0T DSG S line
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Quote Originally Posted by gdbarratt View Post
    Cool, if you can find out which sensor it is then it would be much appreciated.
    Quote Originally Posted by Artimus View Post
    No mate, 36.5 degrees C!
    8P2 S3
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Okay I got VCDS on the car last night and I have the following readings:
    • Fresh air intake temp (G89) -50.0oC
    • Ambient temp (filtered) 37.0oC (this is the same as shown on the DIS)
    • Ambient temp (G17) 41.5oC
    I found some useful info here: Audi Portal: Sensors Diagnostic . Audi A3 8P (2003- ). G89 Описание
    And here: ElsaWeb - Removing and installing ambient temperature sensorG17
    Which sensor may be faulty though? Or is it both?!
    8P2 S3
    Jul 2011
    Congleton
    67
    My car is back from its service and they replaced the temparature sensor for £49 including parts labour and vat, all working fine now
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    That's not too bad, any idea which sensor?
    I plan to have a proper look on Saturday.
    8P2 S3
    Jul 2011
    Congleton
    67
    The car was brought back without the service paperwork which they are posting to me, when it arrives Ill post part number replaced.
    Jul 2011
    Congleton
    67
    Got the bill, they changed the Outside Temp Sender (A8Z0 820 535) cost £17.95 for the part and they charged me 18mins labour to change so must be an easy job.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Right I think this is the temp sensor, near-side and behind the grille:
    is that right anyone?
    If it is it's a defo bumper off job!
    8P2 S3
    Jul 2011
    Congleton
    67
    As they charged just 18mins at garage I doubt the bumper has to come off, must be a simple unplug and replace.
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    That's why I'm confused. A Google image search for outside temp sensor brings up sensors that look like mine above but there's no way I can get to that sensor without taking the bumper off. I know it's in slightly different places for different models but I want to be sure before I start taking the front end off!
    8P2 S3
    JamesS4cab's Avatar
    Mar 2008
    1,122
    I think the A3 is in the wheel arch so wheel off and change, whereas the S3 is behind the grill - hence the bumper off!
    Staz - Did you ever get this sorted? Was it bumper off?
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    Staz's Avatar
    is a retronaut
    Oct 2006
    Bristol (mostly)
    6,168
    Although I have replied to your PM James, I will reply here also for others to see.
    I hadn't got around to sorting this issue but it seems to have fixed itself now the summer is here.
    It's definitely the right sensor though and you'd need to take the bumper off to get to it.
    JamesS4cab likes this.
    8P2 S3
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Thanks matey - i took a quick look last night and tried to contort my arm to get in from underneath etc but for the sake of my blood and skin, I will just remove the bumper.
  1. MAF readings too low?
    By goldy1234 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th May 2013, 09:03
  2. Heater blowing cold and temperature gauge reading too high
    By TDIQ in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2011, 15:06
  3. Temperature Gauge Hitting 120 Degrees?
    By stevewicks in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th March 2010, 14:32
  4. Temperature gauge not reading - unplugged?
    By S3Lol in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th August 2009, 19:43
  5. temperature gauge over reading?
    By andyollie in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st January 2005, 16:45
