Sky InsuranceEM Tuning
Results 1 to 8 of 8
    Sep 2012
    20
    Low coolant when cold 2.0 TDI
    Hi,
    This morning when I started my car I got a warning message telling me that my coolant level is low, checked under the hood and saw that it was on the minimum line, after i drove 20 meters it stopped to warn. Checked after 10 minutes the coolant level have rised again and now stable between min and max.
    Normally the coolant level is on max but it seems that when cold(-14C this morning) it drops to minimum, why is that? bad coolant fluid?
    My engine is a "03G 103 308 B years 2005.5 to 2006.6 only a few cracked". Hopefully I don't have problems with cylinder head
    Nov 2012
    York
    39
    Coolant should be between min-max when the engine is cold, it will rise when the engine warms up.
    I would check you don't have any leaks, top the fluid up and see if you are losing any.
    SAiLO's Avatar
    Enthusiast
    May 2009
    UK
    939
    Scrape the coolant level sensor rods in the coolant tank with a knife. Job done.
    VCDS USER
    Sep 2012
    20
    Quote Originally Posted by syko89 View Post
    I will fill it between min-max when the engine is ice-cold tomorrow
    sliced's Avatar
    Drive safe, stay alive.
    Jun 2012
    1,217
    this happened to me too! just added a few mm extra of coolant and voila, problem solved
    Sep 2012
    20
    Quote Originally Posted by sliced View Post
    How long time ago was this? I really like the car but it starts to annoy me with all these issue.
    Josh84's Avatar
    Feb 2011
    Leeds
    74
    Also happened to me last week. Put some more coolant in and the warning has gone.
    Nov 2012
    York
    39
    If your topping it up with distilled water it might be worth getting a coolant freeze temp kit from halfords.
    They are only about £2 but will tell you at what temperature the coolant will freeze (the more water in the mix the higher the freezing point).
  1. A4 TDI no power when cold and slight coolant loss
    By lukefaichney in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 26th June 2012, 11:45
  2. slight judder when cold 2.0 tdi
    By arnoldlog in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th March 2011, 20:20
  3. Problems with 2.0 tdi running rough when cold
    By Pedro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 17:25
  4. Arrrrrrrghhhhhhhh! Coolant low on recently purchased 2.0 TDi
    By The_Sly_Fox in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st February 2008, 11:29
  5. Hunting/surging at low speeds when cold
    By Eeef in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th November 2005, 17:26
