Results 1 to 10 of 10
    Sep 2012
    37
    A3 2.0T TFSI engine cover
    I broke my plastic engine cover getting it off, pig of a thing to get off also the plastic pivots that it sits on had broken off
    i managed to get some new pivots from VAG 8 quid and a guy on ebay is selling a cover off a 2011 2.0 TFSI
    mines a 57 plate, does anyone know if the cover will fit mine or have they changed? mine is the square shaped one with the air filer built in.
    thanks
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Check if yours has air filter built in. Newer covers without the air filter will not fit.
    Jul 2010
    561
    By plastic pivots do you mean the rubber stoppers that join the cover to the mounts on the block?
    Sep 2012
    37
    yes mine has the air filter built in, are the newer one different
    Sep 2012
    37
    Quote Originally Posted by Minstadave View Post
    no not the rubbers, the pivots that the rubbers push onto both the ones at the back had perished they screw into a heatsheild
    Sep 2012
    37
    i mean these pivots, the 2 at the back marked in red had crumbled, i have replaced them already it's just the cover i need now
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Mk5 Golf GTi use the same system.
    Newer engines have totally different cover, but I believe (correct me if I'm wrong S3 users) S3's still use the style cover in your pic.
    Sep 2012
    37
    thanks they are different the guy sent me a pic.
    not sure about the s3 cover it looks very similar
    Sep 2012
    Brum
    299
    Don't bother. Fit a forge twin take and shut the bonnet and enjoy the noise.
    Jul 2010
    561
    The S3 engine cover with the integrated air filter fits the standard 2.0T.
  1. will a plain Audi TFSI Engine cover fit an S3
    By nelson19uk in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th February 2012, 12:04
  2. A3 8P 2.0 TFSI Engine cover (damaged)
    By Audi-Rog in forum For Sale/Wanted - Audi Parts
    Last Post: 13th June 2011, 09:47
  3. 2.0 TFSI Engine cover
    By B-J-P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th April 2011, 10:31
