JMB RetrofitsBadger5
Results 1 to 8 of 8
    ilim's Avatar
    Nov 2011
    632
    Exclamation Strange noise from lower engine!
    I've noticed a strange noise coming from the bottom of the engine, sounds like thudding, but this only happens when on cold start ups. I have checked the oil and it was below half and filled it up (on my sloping drive way) so I have a slightly over the max. Is this just a common noise. There is not error codes, I'm assuming it might be the clutch. Cars 2012 July, manual, with 4800 miles on the clock and shark remap stage 1!
    Thanks in advance
    Ilim
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    so is the car actually over-filled with oil or does it only show over when on your sloping drive? also, did the knocking start after topping up your oil or before?
    2009 A3 SB 2.0T DSG S line
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    The oil is slightly overfilled at the minute, about 10mm over the mac line so nothing that should be causing any real issues.
    Might be worth waiting and checking again once it's had some drained? That way if the noise is still there you'll know it's not from the excess oil?
    Daytona Grey A4 3.0 TDi Quattro S-Tronic Black Edition
    Artimus's Avatar
    Short Back
    May 2012
    Hertfordshire
    1,869
    over-filling can blow seals through excess pressure, also the piston skirts may hit the oil if excessively over-filled, causing bottom end noise.
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    Quote Originally Posted by Artimus View Post
    Yeah, can cause serious issues! He filled it four weeks ago and it isn't that excessive so I'm doubting its that to be honest... A VW tech is having a look at it tomorrow anyway just to be sure.
    ilim's Avatar
    Nov 2011
    632
    yep filled it more than 4 weeks ago, and have done around 500miles+ drove it at 3 digits, but a vw tech is looking at it tomorrow just to make sure its fine and drain the excess oil out. :-)
    ilim's Avatar
    Nov 2011
    632
    or im just PARANOID...eh dan
    Daggerit's Avatar
    Feb 2012
    Aberdeen
    901
    Quote Originally Posted by ilim View Post
    Yup! But then you do tend to break cars... Haha.
  1. strange noise from engine
    By khalil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2008, 22:53
  2. strange noise from under the car?
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2007, 18:48
  3. strange noise from rear of car @ 4500rpm +
    By darko in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2007, 17:50
  4. Strange noise from intake system on 1.8TQ
    By Platinum70 in forum General Technical / How To
    Last Post: 4th July 2006, 13:12
  5. Strange noises from the engine
    By tfox in forum Diesel forum
    Last Post: 5th June 2006, 12:14
