Badger5JMB Retrofits
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Hitachi fuel pump help.....
    Ok so i changed my cam follower yesterday and when putting the car back together noticed a fuel leak from one of the bottom lines going into the pump....
    Its the banjo fitting to the left ( as u look at from front of car)
    So we un did the spline bolt again and took the pump off to find the banjo bolt has snapped in the pump
    I should be able to get this out however
    Can any one help with
    -can i buy a bolt and re fit it?
    -have this happened to anyone on here? How did u fix it?
    Someone help
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Anyone?
    radhaz's Avatar
    Sep 2012
    Monterey, CA
    If no debris got into the pump, you should be able to just replace the bolt. Make sure you torque it correctly, and use new washers.
    High pressure pump fuel rail injector 2.0ltr.. Fits: Audi | Jim Ellis Audi Parts
    Jul 2011
    106
    Re: Hitachi fuel pump help.....
    Not the same situation, but I stripped the fitting on the right once. I found that the dealer doesn't sell the fitting separately from the pump (at least the one on the right,) but luckily the parts guy hooked me up. He went and found a pump that was going back under warranty and swapped the fitting for me.
    Wish I could offer you more advice, but worst case scenario, maybe a friendly parts guy can help you out. :thumbup:
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    Hope i can get one tomorrow really do...
    Thanks mate
    Johnson3's Avatar
    Sep 2012
    S wales
    58
    All sorted
  1. Fuel Pump / Relay help
    By Aaronneal in forum A3/S3 Forum (8L Chassis)
    Last Post: 3 Days Ago, 16:10
  2. S3 fuel pump help - wrong part?
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2012, 08:25
  3. Ticking on 1st ignition, could be from the fuel pump??? Help
    By haytch75 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th June 2011, 16:19
  4. help with in-tank fuel pump
    By SteveBAM in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st April 2010, 09:03
  5. 2.5 TDI Quat won't start - electric pump in fuel tank help !
    By RogerTDI in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2007, 10:41
