Chris NottAH Fabrications
    Jan 2012
    111
    Audi A3 FSI 2.0 Coolant Warning, Emission Control System Warning light. & Servicing
    Hi, a few problems I would appreciate some advice on.
    I have an Audi A3 54 plate FSI. I've had the coolant warning beeps and warning coming on my DIS for about a month or two. I did read on here around when it first started to happen about the sensors could need cleaned. Unfortunelty I've been very busy and didn't look further into it. Mostly when it first started happening, after I drove for a while or over bumps the coolant warning would go away. I figured it might just go away but it's hasn't. The fan also comes on faster / harder, for example when I turn of my car engine off I can hear the engine fan roaring away for about 10-45 seconds afterwards. On checking the coolant it is between the min and max markings (maybe more near the min but above that line)
    I've seen posts (whilst searching) that say that you can clean the sensor with the coolant tank still attached to the car and that you can use a flat headed screw driver or similar to clean the prongs of the sensors. I was wondering though, would the scrapings from cleaning the prongs in that way cause a problem? as the scraping would be floating about in the coolant tank.
    In the last 2 weeks I noticed that I've had the Emissions Control System light come on my dashboard. It is just lit. On searching on here I will check out the fuse F8 (if i remember correctly) in the engine bay fuse box to check if that is blown.
    I've seem vagcoms mentioned to find faults etc, what other makes and models of cars can they be used on? as I'm not sure how long I will be keeping the Audi for yet, it would be good to know. (I got a load of uni work to do hence my limited time to do all the research.
    My car is also in need of a full service, I'm trying to work out a good garage in or around North London. I phone Russel Automotive Centre and they were charging £250. Looking on Audi's fixed prices they are charging £299. I also think it's time to get the cambelt and water bottle changed. Not sure if I should use either of them or go local as I'm not sure how long I want to keep this car for. Russel Automotive Centre for Cambelt etc is £435, Audi is £429 but I dont believe that includes water pump.
    Thanks for any help
    Jan 2012
    111
    i just checked the F8 fuse in the engine bay and that looks fine, so it's not that, that is causing the Emissions Control System warning light to be on. Does anybody think that it could be related to the coolant problem or is more likely to be a seperate problem?
    Jan 2012
    111
    Quick question if I keep driving my car like this can I mess it up or cause more damage? I aint really drove it for the last week. I'm going to take it to a garage as soon as I work out what one as it needs a full service. But, if I could sort out the Emission Control and Coolant problems it might save me a bit. From looking on the net somebody suggested using a toothbrush to clean the prongs in the coolant tank, it was a different car though. I don't want to cause any other problems so thought I'll ask first if you guys think that would or wouldn't work.
    JPK
    May 2012
    278
    If your coolant is at the correct levels. Then you likely have a faulty sensor in your coolant tank. The coolant tank has the sensor built into it and the part doesn't cost a lot (probably 50gbp or so).
  1. audi a3 tdi sports 140 emission control system light on dash
    By jay6392 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2012, 19:46
  2. Warning light help - emission Control system
    By a3tazza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th March 2012, 18:37
  3. Replies: 7
    Last Post: 1st February 2012, 13:09
  4. emission control system warning light flashing............
    By tisinthepark in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th February 2011, 17:02
  5. Emission Control System
    By migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th May 2007, 14:50
Tags for this Thread
