Chris NottAH Fabrications
Thread: bov and stronic
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    286
    bov and stronic
    is a blow off valve still effective with stronic?
    i ask because of the speed at which the stronic changes gears and lets say you are heavily on throttle, will the bov respond as well/same as/better than the diverter valve??
    im looking at getting a bolw off valve adapter, so curious to your input
    (ps have stage 1 APR map)
    cheers
    +incoming (64/Sep 1st) S3 (300) Sportback S-Tronic Quattro Daytona Grey
    -outgoing (63) A5 2.0TDI (177) Coupe Black Edition S-Tronic Quattro Phantom Black
    VCDS Location: NI (County Antrim)
    - (62) A1 1.6TDI (105) Sport Manual Sportback Brilliant Black
    - (62) S3 (265) Sportback Black Edition S-Tronic Quattro Phantom Black
    - (58) TT Roadster 3.2 V6 (250) S-Tronic Quattro Phantom Black
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    Are you on about the forge spacer?
    If so, It is still a bit effective but if you want that sort of noise the intake will do it louder and improve throttle response.
    The spacer does sound a bit naff if I'm honest. Dont do it....
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    monopole's Avatar
    limboitis
    Oct 2012
    County Antrim
    286
    yeah the forge spacer. do you just recommend the upgraded diverter then with a S1 map?
    i am also waiting for a neuspeed p flo kit (somehow the order seems to have been messed up)
    mjr901's Avatar
    Nov 2011
    Worcestershire
    2,785
    As you have a late 8P, the DV is the latest revision. So DV fitted is good mate, arguably just as good as the pretty forge one.
    I'd leave that all alone, just get the intake on and youll have all sorts of noises
    Jul 2011
    106
    Re: bov and stronic
    Vacuum actuated BOV works fine with S-tronic. Be sure to tie the stock DV somewhere and keep it connected to the electrical lead, else you will get a code. On a WOT pull, the car will only drop a couple PSI at most while shifting.
  1. 3dr A3 and a baby...
    By Ken in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2011, 08:47
  2. BOVs and getting low
    By xcore in forum A4/S4 forum(B5 Chassis)
    Last Post: 10th October 2009, 00:36
  3. bov and mbc
    By s4 osh in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd September 2009, 13:43
  4. LLTEK's new D-BOV for Audi, and stock turbo
    By rafA4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th February 2004, 14:27
  5. Pic and Details Of Next Gen A3/S3
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2003, 23:06
