hi all
Something changed about how the car is turned off. Previously I turn off and the car the interior lights stay off, doors still locked and I can still use the Bluetooth to talk while key is still in ignition. The interior lights turn on, door unlock and bt is off when I remove ignition. Now that happens as soon as I turn off the car and key still in ignition. This is annoying as I sometimes use the bt with ignition off.
Is it some sort of VCDS setup? I did play recently with it while changing the drl set-up.
Thanks for ur help.
