JMB RetrofitsEM Tuning
Results 1 to 14 of 14
Thread: plasti dip
    Oct 2012
    492
    plasti dip
    hi i want a black grill on my s line and the cheapest solution seams to be plasti dip do they do a satin black and do you have to put something behing the grill to stop it coating the radiator and wheres the best place to get it in the uk , if anyone has coated there grill while still on the car any advice would be great as i dont realy want to remove the bumper and grill cheers
    Oct 2012
    30
    i have seen a thread on here ,have you done a search
    bleedout's Avatar
    Sep 2012
    Musselburgh, Scotland
    69
    done it both ways to my a4.
    if you want to leave it on the car put cardboard behind the grill / in front of the radiator to stop overspray effecting it.
    if you can though i would advise removing the grille as it lets you wash it( did mine in the sink), dry it off, primer it (not essential but helps) and means you can spray it up and leave overnight somewhere warm and dry for the plastidip to cure fully before re-attaching to the bumper / car.
    Driver of the big Blue English Springer Spaniel bus........
    Ownded Cars:
    140 BHP A4 Avant "Spaniel Bus"
    300 BHP Focus ST3
    150 BHP Astra Sporthatch
    130 BHP Stealthed out DERV Corsa
    Oct 2012
    Warrington, North West
    986
    plasti dip
    How easy is it to remove the grill and chrome surround?
    bleedout's Avatar
    Sep 2012
    69
    if its anything like the A4 grilleyou pop the bumper of and its 8 torx bits. longest part was running the warm water to wash the grille before hand.
    just make sure you clean and dry it well as if one section comes away it will pull the rest off with how plasti-dip cures.
    i used standard halfrauds plastic primer on mine as well just to help it adhere even better.
    Ownded Cars:
    300 BHP Focus ST3
    Oct 2012
    492
    everyone seems to be out of stock of black airosol plasti dip
    Not low, still slow
    Aug 2012
    Norway
    58
    Not very hard.. Took me about an hour and a half to take it of, change the grill and put it back on The chrome frame is pretty easy to remove as well..
    A3 8P2
    Detailing
    JamesS4cab's Avatar
    Mar 2008
    1,122
    Did you rub the old grill down at all??
    "Dont get me wrong. Ugly girls need loving. Just not by me."
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Quote Originally Posted by bleedout View Post
    Primer it?
    noooo don't do that.
    The whole point of Plasti Dip is for it to be removable when you had enough and take it back to standard colours.
    If you are going to primer it you might as well just paint it.
    Quote Originally Posted by JamesS4cab View Post
    No.
    Just clean it and paint it.
    The whole point of Plasti dip is its not a none permanent colour change to your car, shoes, boat, bike, shed, dash or any thing else you want to paint (Apart from cloths, that's kind of permanent). When you are finished with that colour and you want to change, you can peel it off (recycle it if you want) and put a new colour on or back to how it was.
    Priming or sanding kind of kills the whole point of plasti dip and you might as well just go with normal paint.
    Black Plasti dip sells out very very quickly, so you need to get in and buy it when its in stock. you might be able to find people on ebay selling it but they normally jack the price up cause they know its at a premium.
    If the weather was better I would offer to paint it for you. I got 10 litres of black, 5 litres of gun metal and 750ml of fluorescent red (you never know, you might like it) but due to the cold weather and not having any where in side to paint, I have to shut down plasti dipping during the winter. Which is really annoying and does my head in.
    New Car, New Thread: Scott's Akoya Silver A8
    Gone But Not Forgotten: Audrey's Build Thread
    bleedout's Avatar
    Sep 2012
    69
    Quote Originally Posted by ScottB5 View Post
    Primer it?
    Must admit i used the primer as dont intend on ever removing this colour from my grille. Reason i used plasti-dip was because i prefered its Matt black to anything i had seen come out a paint booth.
    Ownded Cars:
    300 BHP Focus ST3
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    That's fair enough.
    It can have a very nice texture.
    bleedout's Avatar
    Sep 2012
    69
    agreed on the finish, had a look at getting my works paint booths to do a matt black for me but came out still way to smooth and glossy for my liking.
    Ownded Cars:
    300 BHP Focus ST3
    ScottD3's Avatar
    Nov 2010
    English Riviera
    15,019
    Spray further away and on a hotter day you will get some more lumps then.
    You can get a less smooth finish but it means messing about with the mixture and the gun setting.
    When I first did my roof it was rough, its still a bit rough but not as bad.
    bleedout's Avatar
    Sep 2012
    69
    Sorry shouldve said i did my grille with a rattle-can. paint booth stuff was all propper paint gear etc using a non plasti-dip Matt black.
    one plus side to working in manufacturing is i can get all these bits done / do them myself.
    just need decent weather toi plastidip my horrible chrome window surrounds
    Ownded Cars:
    300 BHP Focus ST3
  1. Plasti Dipping offer
    By ScottD3 in forum General Automotive Chat
    Last Post: 5th February 2014, 12:15
  2. How cool is this.. PLASTI DIPPING YOUR CAR!!!
    By ilim in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2012, 09:01
  3. Plasti dipping
    By Brodster in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th May 2012, 08:24
  4. Anyone used Plasti Dip on a front grille?
    By munchkincoupe in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd February 2012, 20:09
  5. Anyone ever used plasti dip
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th January 2012, 13:42
