Chris NottAH Fabrications
    JS3
    Oct 2011
    209
    Milltek Catback Install on a Standard 2010 S3 S-Tronic
    Hi guys,
    Apologies for the newbie question here but I believe that in order to fit a Milltek catback system I shall need my car mapped or coded. Can somebody please confirm what I need? Can this be easily coded via VCDS or do I need a map like Revo Stg 1?
    Also, what happens to the butterfly valve controller in the tailpipe of the OEM exhaust? Is it removed completely or just zip tied to the chassis out of the way?
    Thanks in advance for your help!
    2010 S3, Sprint Blue, S-Tronic, RNSE, Cruise Control, Interior Light Pack, Upgraded LED Interior Bulbs, Heated Seats, Hill Hold, Boot Buddy, Fog Turn Lights, Revo Stage 1, De-Wipered
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    you wont need mapping, you would benefit from it
    no coding required, the mapping cannot be done via vcds
    i belive the butterfly valve is vacuum operated so can be removed completely or you can modify your milltek to accommodate it your choice
    2007 S3 PhantomSchwartz
    Spec | Auto Lights | Black Headlining | RNS-E with 6 CD Changer | Phone Prep | Facelift Tails | MFSW | Cruise | Bluetooth | Adaptive Bi-xenon Headlights |
    Mods
    | MY10 Facelift | 75% LED's | Sepang Bronze Facelift Alloys
    Plans | LED 3dr tails | BBK Setup | Some BBS | Custom TBE |
    Quote Originally Posted by N8
    Yes, but they are OEM Phaeton Helios alloy wheels, not cheap ****e aftermarket piles of poop.
    JS3
    Oct 2011
    209
    Thanks PH1L - which forces the question - what does the butterfly valve do, and what is it's advantage? Assume Milltek alteration would be difficult.
    Wondered if it was a quick code in VCDS thats all, understand mapping cannot be done via VCDS. Thanks!
    PH1L's Avatar
    Gievf Buckets
    Forfar, Scotland
    3,862
    cant really see much advantage in it tbh other than an annoying tick haha
    no coding required to remove the valve its not connected to anything afaik
    Mods
  1. Audi s3 8p milltek catback fitting !!!??
    By Wezcubbages3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st January 2012, 12:35
  2. Replies: 2
    Last Post: 16th October 2011, 12:30
  3. Milltek catback
    By wolfbane1967 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st May 2008, 20:03
  4. Milltek CatBack...
    By jm-baker in forum Awesome GTI
    Last Post: 19th March 2008, 16:03
