The tailpipes on my s line tdi turn down at the end and I see that most others point strait out which looks far better do Serbian models have the strait pipes and do those backboxes fit my a3
No need to change back box, the droopy pipes can just be ground off with and angle grinder thn you can just fit straight tips to replace. If you have a good look you will see that the downwards tips are welded onto the end of your exhaust. I did this on my car a couple years ago and used tips from eBay
