Badger5AH Fabrications
Results 1 to 15 of 15
Thread: s3 idling funny
    Sep 2010
    St.Andrews
    59
    s3 idling funny
    My s3 started idling weird tonight i drove about 8 miles and then was out car talking to someone then jumped in the turn round and noticed revs dropped down really slow then changing gear was getting backfire once home i took it out of gear and let it idle and its fluctuating between 2000 rpm and just below 1000rpm going up and down and if i rev it there is a back fire too any ideas? Got an ig maxogen fitted and full miltek turbo back exhaust
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,786
    Quote Originally Posted by c6dsy View Post
    you could try cleaning the MAF.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Sep 2010
    St.Andrews
    59
    where is it? and clean it with what?
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Vacuum leak. Oil filler cap seal leak.
    Sep 2010
    St.Andrews
    59
    Quote Originally Posted by MrLapou View Post
    Cant seem to find any leaks but when I turn it off the circular plastic bit on front of rocker cover hisses away for a bit maybe 15 seconds it has a small hole that is meant to be there that's where air is coming from
    Oct 2011
    stroud
    24
    s3 idling funny
    PVC valve common fault
    Sep 2010
    St.Andrews
    59
    Quote Originally Posted by 170sam View Post
    just replace that then see how it goes?
    Oct 2011
    stroud
    24
    s3 idling funny
    My bad pcv valve
    Oct 2011
    stroud
    24
    s3 idling funny
    Yea replace it I'm sure it will fix your issue
    Oct 2011
    stroud
    24
    s3 idling funny
    Yea just replace it and I'm sure it will fix your issue for you .
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Try taking cover off with engine running to see what happens.
    Sep 2010
    St.Andrews
    59
    if i take oil cap off it runs worse then air hisses out valve at front i will try pcv valve
    jaydav2306's Avatar
    What is a PCV valve and what does it do????
    2009/2010 | Audi S3 Black Edition Ibis White | Black Optics Pack | Fully Loaded | S-Tronic
    Sep 2010
    St.Andrews
    59
    Quote Originally Posted by jaydav2306 View Post
    Its a valve on the front of rocker cover that takes breathers from block and inlet manifold and has a diaphragm in it to alow them all to breath, seems if diaphragm breaks air leaks straight to inlet causing idle to fluctuate
    jaydav2306's Avatar
    Is this the thing located on the top left hand corner above the oil cap? Good to know
  1. Funny Idle and 15mph-30mph jerky
    By Pixelsharp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st October 2010, 15:25
  2. Funny Idle on 1.8t after Batt disconnected
    By PhilR in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th January 2009, 23:17
  3. funny noise when idleing on a3 tdi
    By ste_1210 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th December 2008, 14:58
  4. Rough Idle
    By melman in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th April 2007, 19:29
  5. F1 Funny!!
    By PunjabiA4 in forum Motorsport
    Last Post: 11th June 2006, 18:42
