Chris NottAH Fabrications
Results 1 to 16 of 16
    Oct 2008
    14
    2010/2011 LED Rear lamp for Sportback coding using Kufatec device.
    Hi
    Has anybody used this device from Kufatec to recode their car after fitting the updated 2010/2011 LED Rear lamps to a Audi A3 Sportback with the adapters method of wiring.
    (I have no access to a VAG-COM lead)
    Diagnostic Interface LED rear lights Audi A3 8P Sportback-37009
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    436
    If I were you I'd save my money and look at the map in the VCDS section for someone near you that already has the software.
    Most people do it for Beer Tokens
    Where about's are you?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Oct 2008
    14
    Coventry
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by hambo0 View Post
    Coventry
    Click on, and enlarge the map, pick a flag close to you and PM the lucky winner !!!
    VCDS (formerly VAG-COM) forum
    Oct 2008
    14
    Finally managed to borrow a VAG-COM cable and I am all set to do the install next weekend of my 2011 Sportback rear LED lights.
    I have searched the forum and want to just double check the coding I need to do.
    This is what I am going to code my car to :
    Go to Central Electornics on VAG COM and go to coding -> help with long coding
    Btye 9 to Dec = 0
    Byte 10 to Dec = 0
    Byte 12 to Dec = 36 or 48 if you want them to be brighter
    Byte 19 Bit 2 Cold Diagnosis rear active
    The only question I have as a total novice to VAG-COM is I have checked quickly me current settings as below
    Btye 9 DEC1: 22 X 1 = 22
    Btye 10 DEC1: 0 X 1 = 0
    Btye 12 DEC: 22 X 1 = 22
    Btye 19 Bit 2 is already ticked.
    If i`m correct its the values on the right that I change as above, but which value is it, the first ot second digit. (ie the 22 OR 1 on Btye 9)
    I would appreciate any assistance :-)
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    The first digit mate. Basically for example, when you select Byte 9, you should then be able to highlight the box and change the end figure.
    It will make sense when you put it in practice mate.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Oct 2008
    14
    Thanks for the assistance will give it a go at the weekend
    Oct 2008
    14
    Hi have spent the afternoon fitting my 2011 LED Rearlights.
    I have come to the coding part and hit abit of a problem,
    i have gone into the Central Elecs, then Coding, then long coding helper and changed the Byte 9, 10, 12 and 19 etc as instructed by changing the first value on the right of the screen ie 22X1=22 I changed the 22 to 0 in my case.
    The problem when I click exit I get a window appear which states;
    This appears to be an uninitialised control module, valid WSC/importer/equipment data may be required.
    Click (Yes) for VCDS to use default values 12345/123/12345
    Click (No) for VCDS to try the values currently in the module
    Click (Cancel) to go back and manually edit the values
    Any ideas what I have done wrong?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Click "YES"
    Oct 2008
    14
    You a star. Works perfectly. Cheers :-)
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    No worries, anytime :-)
    26,716
    Just purely means the module hasnt been given the workshop/importer/installer codes as it has been the same since factory installed, so shows only zero's.
    You can go into vcds options window, then user interface tab & within this section setup the default codes to use when such situations arise.
    Oct 2008
    14
    Thanks for the response I will try and take a look at the codes today, tomorrow when I get chance.
    Question would you recommend the setting of 36 or 48 on Byte 12 for the brightness?
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    All installs I do, I set it at 48. TBH, there is minimal difference I found.
    May 2013
    Hello I am looking to do this led upgrade also, looks so much better. I know i will need to get someone to do the coding after install but can the vag com also turn off the bulb out computer so I can have led drl bulbs without bulb errors coming up. I have in at moment with resistors and no bulb errors during day but when I start car and headlights come on straight away (night) the fault comes on as the drl are not being used so I have to turn off headlights so it turns on bulbs, wait for computer to do check and see bulb is working and then turn back on headlights. Does not do it all the time but it is annoying. It is an a3 sport back 2006. Thanks for any reply.
    Mindak's Avatar
    Nov 2013
    Wiltshire
    175
    Were you successful with this? Lol
    A3 2.0 TDI S-Line
  1. B8 led rear lights for a B7
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st October 2011, 20:52
  2. Coding For A3 Sportback Led Rear Lights Retrofit
    By Stampie in forum VCDS (formerly VAG-COM) forum
    Last Post: 16th September 2011, 20:56
  3. Vag Com coding for SportBack rear lights??
    By guffy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2009, 07:29
  4. Rear side window blinds for sportback?
    By imported_highlander1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2005, 16:16
  5. LED Rear Stop Lamps?
    By liam1234 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th June 2005, 11:57
