EM TuningAH Fabrications
    Sep 2012
    Grimsby, Lincolnshire
    72
    Hatchback/Sportback/Quattro exhaust differences.
    I've got the opportunity to buy an aftermarket backbox from a non-quattro TFSI.
    From a bit of research I've discovered the exhausts are different for the different flavours of the A3 TFSI.
    What I would like to know is how much different.
    Is the physical back box the same? just the pipe that runs into it different? Any pics would be very helpful.
    I'm pretty handy with a welder and fitted quite a few exhausts to cars that needed modification of some sort or another. But I'd like to start with something pretty close so I dont have to make too many alterations!
    Aug 2011
    277
    Am led to believe the cabriolet is also different, but understand an S3 backbox will fit
    RobinA3's Avatar
    Aug 2005
    Cheshire
    1,758
    There is a big difference in the shape of the backbox between the Quattro and non Quattro exhaust so not really worth bodging to fit. I can confirm that the S3 exhaust will fit a 2litre TFSI Quattro.
    Acheron's Avatar
    Jan 2012
    South Africa
    263
    ...and the differences between 2-door and Sportback exhausts? (I see Milltek as an eg sell 2 diff exhausts for the S3, depending on whether it is 2-door or Sportback)
    Current: 2010 Audi S3 Sportback S-tronic
    Ex: 2007 Audi A3 Sportback - 2.0T DSG
    Ex: 2008 Opel Corsa OPC
    Ex: 2004 Opel Corsa Lite
    Ex: 1978 VW Beetle
    Sep 2012
    72
    Like I mentioned in the initial post..
    I'm aware all the different versions of the 8p have different back boxes.
    What I would like to know is if the actual 'back box' is the same, (not the tubing).
    I believe this is a quattro sportback exhaust. My gut feeling is the length on the pipe will be slightly longer for a sportback, and the quattro includes the obvious 'diversion' of the tubing to go round the rear diff.
  1. Sportback Quattro / 2wd Towbar different?
    By Avus Sportback in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2011, 14:14
  2. 2.8 quattro Exhaust
    By qA4Blake in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th June 2004, 05:05
