AMD TechnikVolks Autos
    a6-chris's Avatar
    Jan 2012
    1,011
    will 15" rims fit my a3?
    looking at a potential set of winter alloys/tyres for my a3 - they're off a golf mk5 which has the same 5x112 setup - the rims are 15" in diameter
    just wondering if i can go as low as 15" so they clear the brakes? i have a 1.9 tdi.
    tia
    A6 3.0 TDI Le Mans
    A3 1.9 TDIe Sport
    Feb 2009
    Aberdeen
    2,269
    If they fit on a Mk5 they should fit on an A3. They won't fit over 3.2 or S3 brakes, not 100% on the size of the standard discs/calipers.
    Hunt is over
    1st Audi - 2001 Ming Blue 8L S3 210
    2nd Audi - 2008 Black 8P2 S3 3dr
    and now - 2007 Daytona Grey B7 RS4 saloon
    a6-chris's Avatar
    Jan 2012
    1,011
    Quote Originally Posted by MartayMcFly View Post
    thanks, will dig a little deeper! :D
    A6 3.0 TDI Le Mans
    A3 1.9 TDIe Sport
    Ironborn's Avatar
    Jan 2012
    Bristol
    555
    Oh I thought the smallest you could go was 17? Because the front brakes would not allow me to fit a oem spare tyre, only the back would.
    Feb 2009
    Aberdeen
    2,269
    Well after a bit of research I can semi-safely say they'll fit. The most easily searchable car that runs 288mm discs (like those on the 1.9 TDi A3) is the Mk3 VR6 and they can run 15" wheels so you should be ok. You should double check the offset though, since there'll be very low clearance.
    17" is the smallest that'll clear the S3/3.2V6 356mm brakes, maybe that's what you're thinking of Snipe.
    Just as a 'get out of jail free', this is based entirely on internet research done at 2:30am and in no way should be held as gospel.
    Hunt is over
    a6-chris's Avatar
    Jan 2012
    1,011
    Thanks guys - think I will play it safe and go with 16's
    They aren't the prettiest of designs but the set I've found have decent tread on Conti Wintercontacts
    A6 3.0 TDI Le Mans
    A3 1.9 TDIe Sport
  1. will these rims fit?
    By gareth_oau in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd May 2010, 20:52
  2. Will these rims fit my car?
    By M88JCP in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2010, 10:56
  3. Will these size rims fit?
    By piers90 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 23rd May 2009, 19:10
  4. Will german exhaust parts fit Uk model?
    By imported_Yaseen in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th September 2004, 13:32
  5. A8 1997 17" Sport wheels -- will 255/50 17" fit?
    By hanssimon in forum A8/S8 forum
    Last Post: 1st April 2004, 20:52
