Monster MotorsportVolks Autos
    Nov 2012
    57
    Question Repair wires - Earth and power wires for boot lock mechanism
    So this morning i replaced the boot lock catch mechanism which took a matter of minutes BUT the terminals in the electrical connecter are heavily corroded to point where the middle wire (Lock status) has snapped. The preferred option would be to remove the snapped connector using a repair wire (VW Part 000979133E) but as i can't release the securing lugs on the terminal i'm of the opinion the only option available to me is to replace the connector and three wires.
    My question is. Do i need to use a specific gauge of repair wire for earth and power or can i use the same wire for all three.
    Fossie
    Rhubarb Triangle
    3,969
    You can use the same wire for all three !
    Nov 2012
    57
    Cheers Mike. I thought i could but it never hurts to double check.
  1. A little Audio help for OEM Sub and Amp wiring
    By 4NT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd April 2012, 20:46
  2. Fuse ratings and Power Wire Gauge
    By sharma in forum In-Car Entertainment
    Last Post: 25th November 2009, 12:31
  3. Running power wire for A4 B5 and speakers
    By Fluid36 in forum In-Car Entertainment
    Last Post: 27th March 2007, 00:23
  4. Part Number for Door Lock Mechanism/Sensor
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st July 2006, 21:52
  5. 5 Volt and ground wire on MAF
    By dunkmstr in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd May 2004, 20:15
