Monster MotorsportBadger5
Results 1 to 12 of 12
    Nov 2012
    Bournemouth
    37
    8P3 Halogen to single Xenon with LED DRL
    I have a 2010 3 door 2.0l TDI s-line with standard halogens. I wish to replace these with single Xenon (not bi-xenon) headlights with the LED DRLs.
    Just talking headlights here, I already know about leveling and washers, are these a straight swap with a few settings changing in VCDS?
    I have found adaptors for installing bi-xenons but not single xenons.
    If anyone can help, that would be great!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    All 8P3 LED DRL headlights are Bi-xenon, not single, to get xenons to work on yours you would need the adapters, then take two wires on the adapters to your Central electrics for the shutter signal for xenon high beam, then code it to the car.
    Current
    2006 56 A3 S Line 2.0 TFSI Special Edition Moro Blue
    previous
    2007 A3 S Line 2.0 TDI 170 S-tronic phantom black
    2006 VW Golf Gti Black
    2008 S3 Dolphin Grey
    2007 A3 S Line 2.0 TFSI S-Tronic Ibis White
    2005 A3 S Line 2.0 TDI S-tronic Brilliant Red
    Nov 2012
    Bournemouth
    37
    Ah that makes sense! In that case, I remember seeing on the forum that not all units that control the shutter are compatible, how would I be able to tell?
    Many thanks for your help!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    Yours will be compatible, all 8P2 onwards are compatible 55 onwards, I am currently using an 8p2 55 plate sline tdi and that will accept Bi-xenon led DRL, and every other 8P2 I have worked on had it it too. Am guessing your car will already have standard drls been 2010 model so it is 100% anyways.
    Current
    previous
    Nov 2012
    Bournemouth
    37
    Yes, it does have standard DRLs. There is an adaptor like the one you mentioned on ebay from Germany that has the extra cable to control the bi-xenon shutter but it says its for 8P's upto 2009 only. Also, on kufatec, they say "From model 2010 the control unit for central electric needs to be replaced (In some cases models before 2010 as well)". Sadly they dont say how to check and I cant really find anything when searching.
    I'm a bit confused!
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    Firstly do you have vagcom AKA VCDS?
    Current
    previous
    Nov 2012
    Bournemouth
    37
    Yup. Got the Ross-Tech cable and VCDS.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    Ok good well once plugged in, go into 09 central electrics and see what the part number ends in will be a letter
    or go into long coding helper, then byte 21 from what I can remember ( little squares with numbers and/or letters near the top which is 21st along, then should be a drop down box to choose which headlights you have, will say halogen now but I there is an option to choose 05 Bi-xenon led DRL then you have the correct one.
    Current
    previous
    Nov 2012
    Bournemouth
    37
    Awesome! My cable isnt with me at the moment but I can check it first thing tomorrow.
    I take it if the option isnt there, then I am a bit stuffed?
    Many thanks for your help.
    Lewbo's Avatar
    Aug 2009
    Hull
    1,039
    It will be there as you already have a feed for your current DRLS, just double check.
    Current
    previous
    Nov 2012
    Bournemouth
    37
    Hey mate. Went into 09 and went into code helper but cant find the drop down menu in byte 21 or any other bytes, any ideas?
    Nov 2012
    Bournemouth
    37
    Ok, so after searching with the part number of the Control Unit I have in mine (8P0 907 063 A), it appears that I do have the correct one. There is a thread that I found on this forum when searching the PN that had some information 2010 A3 retro to Bi Xenon
    So I assume that I just purchase the cable from Kufatec and select 'From model year 2010' then all should be good?
    Xenon/HID Headlights - Adapter- Audi A3 8P & 8PA Facelift-
  1. Those of you with LED DRL's...
    By lil_coz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th March 2012, 18:35
  2. Adaptive xenons on led drl unit
    By *Müllërz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th January 2012, 00:56
  3. Headlights with LED DRLs
    By Billyboy200uk in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th August 2011, 22:45
  4. 8P3 Owners with Xenons and LED DRL's please help
    By scottie123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th September 2010, 19:26
  5. Replace headlights with LED DRL units
    By bezza in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th June 2010, 15:21
