Chris NottMonster Motorsport
Results 1 to 8 of 8
Thread: gps placement
    Nov 2012
    Blackburn
    61
    gps placement
    i am soon to be installing rns e plus bluetooth in my car. i currently have navigation but only voice guided with the controls next to handbrake with nav cd in boot. where would the gps atenna be connected and how would i bring it round to connect to rns e?
    ryanstewart9's Avatar
    Sep 2009
    Surrey/Hants/Berks
    436
    Do you have the Shark's Fin aerial?
    "If you ain't first, you're last!" - Ricky Bobby
    2008 A3 S-line 2.0 TDI PD140 (Pre-facelift)
    Nov 2012
    Blackburn
    61
    yes i do
    Dannykn9's Avatar
    "Cruise My Ride"
    May 2011
    North London
    1,073
    Then your current gps antenna will be plug and play into you RNS-e.
    VCDS Owner-North London/Enfield
    " To Cruise Is What I Do"
    Nov 2012
    Blackburn
    61
    yes but where will it be loacted? the current system is the concert.its not plugged into there.there is the controls next to handbrake and st nav drive in boot? will the antenna be connected to the drive? and will i have to bring it all the way round?
    Nov 2012
    Blackburn
    61
    the connections on back of my concert inculde one yellow wire and one black wire both seem like aerials? along with the rest of the connections
    Sep 2009
    Surrey/Hants/Berks
    436
    I would assume your GPS antenna would be connected to the drive in the boot as this is driving the sat nav system.
    Not all Shark's Fins have the GPS antenna in them. I changed mine as it only had the BT antenna in it, but you can get the smaller ones which you can fit behind the dashboard.
    Nov 2012
    Blackburn
    61
    so i would need to get behind the drive and reroute the antenna to the front? this is gonne be a tough job lol
  1. Speed accuracy on GPS systems: Navman, Road Angel
    By ashleyminors in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th December 2004, 22:01
  2. cheap gps navigation
    By in forum Detailing
    Last Post: 9th May 2004, 17:29
  3. MOVED: cheap gps navigation
    By ha3t in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th May 2004, 19:46
  4. GPS speed camera detectors
    By stressfrees3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2003, 16:28
  5. Sat-Nav and GPS Camera positions
    By mramage in forum Other Brands & Models
    Last Post: 8th August 2003, 14:34
