EM TuningMonster Motorsport
Results 1 to 7 of 7
    Bailey's Avatar
    Jun 2009
    Alton, Staffordshire
    247
    Windscreen Wiper help?
    Hey Guys
    Bit of a problem this morning, I came down to the bottom of the garden to start up the car and it was a bit frosty. I pulled the windscreen wipers away from the windscreen itself as they were frozen to the screen and in doing so with the driver side one there was a cracking noise.
    So I then started my car up to test the windscreen wipers and the passenger side one works perfectly but the drivers side one is completely dead and doesn't move at all.
    Is this the linkage which has broken? How do I check? If so roughly how much is the replacement part?
    My car is a 2005 2.0 TDI
    Bailey
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Could be the fixing arm nut has come undone. Remove the plastic cover at base of arm to expose the nut.
    Do not over tighten. It may take a few times to make sure the wiper sweeps the screen properly up to the A pillar.
    Bailey's Avatar
    Jun 2009
    247
    Quote Originally Posted by MrLapou View Post
    Ok I will check this thanks for the info. Do you think it sounds like I would need to remove the scuttle panel to check the mechanism?
    Bailey
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Not sure, but on a 2009 car, no need to remove any panels, just take off the small plastic cap at the base of wiper arm.
    Bailey's Avatar
    Jun 2009
    247
    Ok thanks for the advise, I should be getting it looked at this morning
    Bailey
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    How did you get on?
    Bailey's Avatar
    Jun 2009
    247
    How did you get on?
    You were right, it was the wiper nut, I feel such an idiot right about now as it just needed tightening! Thank you so much for your help MrLapou, you are a star!
    Regards
    Bailey
  1. Replies: 1
    Last Post: 21st August 2010, 19:41
  2. Lifting windscreen wipers when washing!
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th January 2005, 12:59
  3. Clever windscreen wipers - or bust?
    By imported_katetodd in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd September 2004, 19:58
  4. Special Needs Windscreen Wipers
    By AndyMac in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2004, 12:08
  5. Front wipers - help!
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th June 2004, 17:20
