Volks AutosAH Fabrications
Results 1 to 7 of 7
    Aug 2011
    90
    Serious braking issue with my car! HELP!
    Okay guys, basically whenever I press my brake pedal more than two times continuosly my pedal immediately goes hard and I can no longer brake, its really dangerous, the only way for me to get my brakes back is to release the pedal for a second or two. I have not got a clue as to whats doing it, I know my rear pads are worn, going to get them replaced this week however with the main issue Ive been told it might be the brake servo.
    Can anyone shed some light on this please.
    Sep 2010
    St.Andrews
    59
    Quote Originally Posted by pandoo1 View Post
    sounds to me like brake servo, possibly air leak to it
    Aug 2011
    90
    Okay cool, you recon I'd need a new one or?
    Nov 2012
    Harlow, Essex
    21
    sounds like an air leak! My old Astra had a similar problem a couple years ago, turned out to be a vacuum hose pipe had a crack in it and under pressure it was opening up, causing loss of breaking power! I wouldnt advise driving it tbh! because if it breaks, then there will be 0 braking power! - get it replaced!
    Also cheap fix if its the above!
    Audi A3 Sline 2.0 TDI Sport 140
    Sep 2010
    St.Andrews
    59
    probably more needing to check air pipes, also there is a one way valve that sometimes sticks check all that first
    c_w
    1,061
    Why are you pressing the brake pedal rapidly? This normally happens as the vacuum in the servo is depleted and the pedal goes firm. Normally takes more than two rapid presses though!
    Mr. B's Avatar
    English...not so good
    Jan 2012
    Bristol
    941
    Well duh, how else do you tailgate lol.
  1. WHAT BRAKE PADS FIT MY CAR???? HELP
    By CO11K9 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 18th September 2012, 20:48
  2. couple of issues with new car
    By 44ark in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2012, 09:58
  3. So many issues with car!!!!!!! Anyone help.
    By s33nyboy12 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2012, 20:32
  4. Big issue with S4 B5, Help please
    By JasonK in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd May 2012, 09:00
  5. problems with new car, help please?
    By xCoupexAshx in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th June 2010, 16:15
