Monster MotorsportVolks Autos
Results 1 to 18 of 18
    Jun 2012
    21
    Boot lock sensor
    I am having trouble with the boot lock sensor, boot is locked but on the screen coming up as open, alarm keep going off. I suspect there is a leak in rear wiper washer, is this a known fault? Left my ca unlocked today!
    Fossie
    Rhubarb Triangle
    3,961
    Well known fault usually caused by knackered rear wiper motor as you suspected. Washer fluid leaks into the motor and then drips down inside the boot lid lining and into the lock.
    Remove the lock and either dry it out or flood it with WD40 type stuff. Temporary fix is to remove the electrical connector and connect the two pins together making the control module think it's locked ! It won't be but the alarm won't keep going off !
    New lock may be required as permanent fix but definitely a new wiper motor. The latest version has been modified to stop this happening.
    Nov 2012
    57
    I replaced the rear wiper motor on my Sportback last weekend and am waiting on a new lock mechanism to be delivered. The hardest part of the job is getting the boot trim off, fitting the wiper motor (gasket failed causing it to leak on to the lock mechanism) is dead easy as it is held in place by three bolts. The lock mechanism looks to be pretty easy as well
    Jun 2012
    21
    Ah so it is the leaky wiper then, I sealed it last winter! Any idea what prices are for the wiper motor or th lock?
    Nov 2012
    57
    Paid £110 including delivery from Lincoln Audi on eBay. Both are brand new boxed.
    Jul 2012
    Essex
    183
    The same thing happened on my Mk 4 Golf years ago, alarm going off randomly, light on dash. Yes it's water getting into the lock, don't go buying stuff until you find out where the leak is, maybe an easy cure if it's a pipe and the bootlock can be removed and dried out, although not always possible.
    May 2009
    West Yorkshire
    1,609
    Nacked wiper motor, i replaced this on my A3 before it was sold.
    Audi A3 2.0L TDI S-Line Sportback
    Nov 2012
    57
    Ignore the quality of the photos as i only had my phone with me at the time.
    Wiper motor. You can see where the gasket between to two parts of the case had failed causing it to leak. The pipe had also worked slightly loose. I tried to repair it using liquid gasket but opted to replace it instead.
    As you can see, water had caused the connectors to corrode (the green stuff) to the point where the middle wire had snapped. The middle wire is the lock status signal which is the reason why in my case the boot light wasn't coming on.
    Fossie
    Rhubarb Triangle
    3,961
    Wiper motor shows as £102 and boot lock as £32 but prices have gone up recently so they maybe slightly out !
    Ring Dave at Stoke Audi and tell him you're an ASN member and he will give you a discount. However postage is on top of that so it may negate the discount !!
    Edit : just found this :-
    AUDI A3 8P 05-08 5 DOOR BOOT LOCK MECHANISM 8P4827505C | eBay
    Nov 2012
    57
    Fossie
    Rhubarb Triangle
    3,961
    That price is £40 cheaper than the current ETKA price !!
    Wonder why they are selling the latest version so cheap ? At that price it's worth buying one for a spare just in case !!
    Nov 2012
    57
    Still waiting on the lock mechanism but the wiper came in a sealed VAG branded box and with a two year warranty. Whats not to like
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by Strangely Brown View Post
    Absolutely nothing ! Think I'll get a spare boot lock as well !!! lol
    MTRL's Avatar
    Split Grill!
    Nov 2011
    463
    Ive got a boot locking mechanism off a 2008 3door boot lid if anybody is interested pm me.
    ....................I'll make a build thread one day.
    Fossie
    Rhubarb Triangle
    3,961
    Quote Originally Posted by MTRL View Post
    Well it might fit but the part number is different between the 3 door and sportback !
    Jun 2012
    21
    Had some time to open it up, the mechanism inside where the jet sits has leaked, I installed an o ring last time but it has perished. the boot lock is fine, its just the 2 pin wire had some condensation on it and the copper pin has corroded slightly, took it off a good clean and wd40 on the pins and the socket and it makes good contact now.
    Opened the motor and installed a new oring and cleaned the waterways and the jets as they were slightly blocked.
    The main shaft tips where connects to the plastic housing has corroded and all water leaks from here, shame as the rest of the motor and parts dont fail appart from this.
    Reassuringly Expensive
    May 2009
    The Mean Streets of Preston
    11
    demi, my car has exactly the same symptoms as the ones you opened this thread with.
    Thanks for the advice guys.
    ..........think I need to go and check my rear wiper motor.
    Just out of interest how easy is the motor to fit? I've replaced a door lock before but not gone near the wipers.
    I'm guessing fairly straightforward.
    Lock "Stock".
    8P1 K&N Air Filter, Dechromed grill, re-map.
    Fossie
    Rhubarb Triangle
    3,961
    Motor is dead easy to change, it's held on by three bolts.
    The biggest problem is getting the wiper arm off the spindle. You may need to use a puller to free it. Like this one :-
    WINDSCREEN WIPER ARM REMOVAL TOOL | eBay
    The second biggest problem is getting the boot card off. Two torx screws behind the number plate (ish) and then some very hard pulling to release the spring clips.
    Once you've got the card and arm off it's a five minute job !
  1. boot lock sensor.....
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2010, 22:23
  2. Call to action!! Anybody who has/had door lock sensor problems
    By VAGMAN1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2005, 18:03
  3. Attn: Anyone who has/had door lock sensor problems!
    By VAGMAN1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2005, 21:23
  4. Door lock sensors
    By sanddancer55 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st September 2005, 11:14
  5. Boot Door Sensor
    By bkmullin in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd July 2005, 11:00
