Monster MotorsportEM Tuning
    Nov 2012
    S3 sportback not starting help pls
    hi,
    this is my first post on this forum and not a great way to start i guess but i was hoping for some help from the community, i have in the past week purchased an S3 sportback 2009 model, it was starting fine and now for the last 2 days i have not been able to start it, i was hoping that someone has either had a similar issue or a knowledgeable person maybe able to assist, some symptoms below.
    i only have 1 key
    car unlocks and locks fine with the keyfob
    battery has been on charge for the last 2 days
    there is plenty of fuel in the car
    car starts for about 2 seconds and then cuts out
    when turning the key the dashboard instruments do not self check any more as they normally do, and there are no other lights or messages displayed on the dash, it is completely blank.
    I am a bit perplexed as to what has happened and any help given will be much appreciated, thanks in advance.
    MrLapou's Avatar
    Jan 2004
    Lincoln
    1,209
    Start by checking fuses..
    mjr901's Avatar
    S3 Pollution Plus+ Edition
    Nov 2011
    Worcestershire
    2,785
    Get it plugged into VCDS and scanned. Thats by far the easiest way to do it.
    It coud be a number of things from the Battery in key (causing imobiliser problem) to a MAF problem.
    2012 Ibis Black Edition S-tronic S3, 3 Door, Shark Stage 2, MTC Intake Kit, Powerflex Fast Road Dogbone Mount, Full Non Res Milltek Exhaust, Forge Development Intercooler + DV system,
    340bhp Mikes Ibis BE 2012 S3...
    Nov 2012
    checked all the fuses, everything is fine. Will get the diagnostics tool attached to it as advised, thank you
    edited: changed the battery on the key fob as well, but no joy,
    Nov 2012
    here is a short vid of what is taking place
    Nov 2012
    Anyone else seen or come across this issue? any help will be much appreciated.
    Thank you
  1. TT APX 225bhp will not start, HELP Please.
    By t955daytona in forum TT/TT-S/TT-RS Forum
    Last Post: 30th June 2010, 17:33
  2. Audi not starting! help.....
    By shaz-raul in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2010, 08:23
  3. S3 not starting??? Help please....
    By Lacey123 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th August 2009, 22:44
  4. S3 nearly not starting - help please?
    By dgannon in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th December 2008, 01:38
  5. S3 nearly not starting - help please?
    By dgannon in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th December 2008, 16:07
