    Oct 2012
    help required by some one with vagcom please. 00655 seat belt problem, cash paid
    hi really need someones help . i have an audi 2006 tfsi 3 door , i'm getting code 00655 (passenger side seat belt igniter) on my scanner tool , however it will not delete. i have spoken to steve at c&R of nottingham and he suggests replacing the passenger front seat belt unit. i've tried every where to get a second hand unit but no on seems to have one available that hasn't been triggered. i cant currently afford a new one £200 due to the time of year . so until i can, could some one in the EAST MIDLANDS area please turn the passenger one off only, so i still have some of my air bag system active in the intrim . obviously ill pay you for your service.
    many thanks rob 07854298907
    Gizmo68's Avatar
    VCDS owner in Kent
    Nov 2012
    Folkestone, S.E. Kent
    85
    Rob that DTC is for the seatbelt tensioner ignitor not the airbag, the yellow plug under the seat is for the airbag:
    00655 - Seat Belt Tensioner Igniter Passenger Side (N154)
    00655 - Seat Belt Tensioner Igniter Passenger Side (N154): Resistance too High
    00655 - Seat Belt Tensioner Igniter Passenger Side (N154): Short to positive
    00655 - Seat Belt Tensioner Igniter Passenger Side (N154): Short to ground
    Possible Symptoms
    • Malfuncton Indicator Light (MIL) active
    Possible Causes
    • Wiring/Connectors from/to Seat Belt Tensioner Igniter Passenger Side (N154) faulty
    • Seat Belt Tensioner Igniter Passenger Side (N154) faulty
    Possible Solutions
    • Check Wiring/Connectors from/to Seat Belt Tensioner Igniter Passenger Side (N154)
      • Check Measuring Value Blocks (MVB)
    • Check Seat Belt Tensioner Igniter Passenger Side (N154)
    Special Notes
    • When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the tensioner to deploy. See repair manual for more information.
    VCDS HEX+CAN owner - covers all VAG cars
    (PM me if you require VCDS coding in Kent)
    MY11 Audi TT TDi
    MY11 Skoda Superb Estate
  1. Any one with vagcom in the southwest???
    By edwards_a3 in forum Smaller (Local) Events
    Last Post: 16th June 2009, 15:05
  2. Any one with VAGCOM near Selby
    By andywa in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th June 2009, 22:38
  3. I might need someone with VAGCOM please!
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2005, 10:36
